Question about Fantom Vacums FM430 Handheld Vacuum
How do you open the hand held vacuum to empty the contents??
    New Friend:
There is Dust cup release need where the power cord connect to the vacuum. Once you have released the dust cup from the vacuum. First the are 4 parts to the dust cup, The actual dust cup, the housing for the filter and mesh screen. The dust cup will unscrew from the the housing which holds the filter and mesh screen. You can also pull out the filter and mesh screen out of the housing, If you have taken it apart fully you will have 4 seperate parts.
Posted on Sep 24, 2012
SOURCE:
Why is my maxi vac not sucking ?
No electricity
broken
hose blocked
bag need emptying
If it is a small hand held machine, they are notorious for burning out motors. Send it back under warranty.
maxi vac Google Search
Jun 13, 2018 | Vacuums
My Dirt Devil KONE Hand Vacuum won't unscrew to empty
sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
Mar 11, 2013 | Dirt Devil KONE Hand Vacuum MO213BLU...
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
Oct 21, 2010 | Dirt Devil Easy Lite Quick Vacuum
Can't get it open to empty it! Help
1. Remove the unit from the base.
2. Twist the top clockwise to separate the two halves.
3. Grasp the filter tab to lift it up.
4. Empty filter, replace, reassemble.
May 22, 2010 | Dirt Devil KURV Hand Vacuum Champagne...
Please tell me how to empty a Dyson Dc05. I don't have instructions. Thanks
Hi its Darran at Dyson.
To empty your DC05, press the button on the top of the machine at the front of the carrying handle to open the lid. Then lift off the cyclone top and bin assembly. Over a dustbin, press the button on the front of the cyclone/bin assembly to separate the two sections. You can then tip the contents of the bin directly into the dustbin.
For full step by step instructions on how to empty the bin, please visit www.dyson.co.ukl/support.
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson DC05 Bagless Canister Cyclonic...
The best dustbuster type vacuums
I would recommend the dyson hand held unit. it is the most powerful hand held out there. the down side is that it only has a 6 to 10 minute charge, but it will work perfectly for your needs.
Oct 07, 2009 | Vacuums
How do i open my dirt devil kone to empty it?
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 21, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
How do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Dec 26, 2008 | Black & Decker V9650 DustBuster Handheld...
Fantom Vacums FM430 Handheld Vacuum Logo
124 people viewed this question
Top Fantom Vacums Vacuums Experts
CJ C
CJ C
Chris Nomland
Chris Nomland
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
