Question about Copystar CS-2020 Copier
Screen showing J00
Hi, expert:
The screen shows J00 & will not work. when I open the side, there is no paper stuck in there. To top it off, I cannot find the manueal. Please help.
Susana
    Sergeant:
  • 329 Answers
If this is the model that I think it is this one stumped me and come to find out it was related to toner. Is the toner bottle full or is the waste toner bottle full. It seems and agian this may not be the model, you have to put in new toner and the machine will run untill it tones up. During that time the machine will not work...Again i have seen this but do not know if this is the correct model, Good luck..
Posted on Jul 22, 2008
Xerox 3435 printer show error on the screen duplex jam 0-check inside
You have to open the panel on the opposite side of where the printed paper comes out. There's Probably a sheet of paper stuck where it flips the paper over to print on the back.
Dec 25, 2017 | Xerox Office Equipment & Supplies
Km2035 error J00 kyocera mita
J00 is an unidentified jam. Means that a paper jammed in the machine and the user switched the machine off and then on again. So the machine lost the ability to inform the user where the jam is. As a result the user has to find out where the jammed paper or piece of paper is.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
Display is showing J00, what is meaning??
J00: means the paper is jammed in the paper pickup step, remove the cassette and pull the paper softly. and reinstall the cassette again. the message will be cleared.
Dec 25, 2010 | Copystar CS-1510 Copier
Shows paper stuck at screen and doesnt have
Have you tried pulling out the whole imaging unit?
Open the top cover and front cover to remove it.
Jan 20, 2010 | Copystar CS-1500 Copier
Error code J00
Code J00 is paper tractions error, either one of the traction wheel or one of the sensor is stuck or defective, often you need to take apart the printer to fix this.
Jan 07, 2009 | Kyocera KM-1510 Copier
Nashuatec Photocopier 3722td
Never heard of this model but looks very similar to a Xerox.
3 places to look for
1-open tray and check no paper is behind or on the way up and got stuck.
2-open right side and check bottom lookin ginto the tray, you should see the rubber tires and a black lever sensor, is the sensor ok, is there any pieces of paper on it, is it stuck??
3-look at the fuser section (where it gets hot) can you see any paper there? sometimes they crumble up and get stuck. You willhave to take out the fuser unit and remove the paper.
Aug 23, 2008 | Ricoh Aficio 2015 Copier
WHAT DOES J00 CODE MEAN
jam 0 means there is one of your switches not working good, it shows that there is jamming but there is no paper, so u have to check which switch is not in right place and fix it.
Jul 10, 2008 | Copystar CS-1620 Copier
Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Jun 12, 2008 | Office Equipment & Supplies
PRINTER SAYS PAPER JAM 23 ..
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Copystar CS-2020 Copier Logo
285 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
