Question about Refrigerators
Sub zero 500 series, ice maker not making ice
  • 2 more comments
  • Anonymous Jul 19, 2008
    nothing happening
  • Anonymous Aug 03, 2008
    Our ice maker a 550 (500 series sub-zero refrigerator freezer stopped making ice. We removed the drawer and thawed the freezer and then replaced the drawer. After 1/2 hour the ice maker still had not started making ice. Is there a time differential when the ice maker will kick on again.
  • etking26 Apr 09, 2009
    My automatic ice cube maker completely iced up - a sheet of ice covered the ice maker and then the water went all over the freezer and of course turned to ice everywhere. I cleaned it up and turned back on the ice maker but nothing has happened. Do I need a repairman? Or is there a solution?
  • tonymiller Apr 27, 2009
    My Subzero stopped making ice after the plumber was by install a new tankless water heater. The water supply had to be cut off -so I assume that there is air in the line like there was to all faucets in the house. How do I bleed the line to ice maker to make it start again? I have toggled the plastic switch triggered by the drawer box moving in and out. The refrigerator has been running continuously.
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
  • 112 Answers
SOURCE: subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Posted on Oct 18, 2008
Ic maker in sub zero 700 series makes ice but it melts into a solid block
What is the model complete number listed on the unit?
Oct 27, 2012 | Refrigerators
I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
Here is a link to a Sub Zero Repair Video
http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
Feb 20, 2011 | Sub-Zero Refrigerators
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero ice maker (Model 235) not making ice, warm inside
try first. condenser ciol clean. is the water cold? is cutter grid in god shape? the brackett under the evaporator is attached?
Apr 02, 2010 | Freezers
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
891 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
