Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Drying slow I am wondering why my dryer is drying slow. I cleaned out all the lint channels all the way to the outside vent. It seems to be heating but not staying very hot? My guess is that it has something to do with the thermostate but not sure. My next question would be how to fix if the thermostate needs changing or the coils are burned out. Thanks from Mr. and Mrs damp clothes. Bro. Marvin.
  • davidsmail Jul 19, 2008
    I own a Fridigaire top load stacked washer / dryer model FEX831CSO. The washer works great however the dryer will only spin with no heat. I Changed the circut breakers, cleaned out the lint trap and made sure the exhaust hose was not clogged. Are there fuses within the appliance that I need to change or do I have a thermostat problem. If so, how to I replace the parts. I thank you in advance.
  • 639 Answers
Hi, Marvin,
My name is Neil and i am happy to help you and give you good advice!
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Or if you like,
You could call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Posted on Aug 24, 2008
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
Tip
Saving money drying clothes
The biggest thing to remember about your clothes dryer is that it has to get the moisture out. If you keep your venting clean it will aid your dryer in shorter drying times. The more heated dry air it can pull through wet clothes while they are tumbling the faster clothes will dry.
If the venting is restricted by lint or kinked, or low quality venting, all end up costing more in drying times. Use good venting, preferably steel, and do use the proper vent cap on the outside wall.(check lint does not catch here also)Many service calls could be prevented by regular maintenance of venting.( thermal safety fuses which all dryers have are the reason for most service repair calls when the venting has not been cleaned) Also the shorter distance your dryer is vented, the better.
The second less obvious problem is not cleaning the lint screen. All the air or almost all passes through this screen before being exhausted outside. You need to clean the lint first. Second you need to wash the lint screen in the sink to clean off any build up of fabric softener that can also cause slow drying. Water should run straight through the metal mesh, if it ponds it is coated with softener, and water should wash this off.(I have been on service calls where dryers were not drying correctly and just washing off the lint screen of fabric softener fixed the problem)
Lastly wiping the two short parallel bars about three inches long found inside the dryer with alcohol to remove any fabric softener or other coating will keep the automatic cycle working right.Not all dryers use these........
Before thermistors, when thermostats were all that was out there.........
Hope this saves you some money and time.......
on Feb 23, 2010 | Dryers
My kenmore 400 dryer takes for ever to dry clothes, does it need a new heating element?
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
May 15, 2010 | Kenmore 400 6942 Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Dryer isn't drying as well as normal.Lint filter is clean.Doesn't seem to work any different on timed dry or auto dry.I have electrical exp. but no dryer exp.What should i check and how do I access it?
i belive you should check the vent hose from the dryer all the way to where it exits the house... that's usually the problem when dryers aren't drying as well as they shoud... lint wil start to cake on the walls of the vent and either create a complete block or slow the air down enough to keep it from circulating like it should
Feb 14, 2010 | Whirlpool WED5300S Electric Dryer
Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Oct 13, 2009 | Samsung Dryers
Dryer is spinning and warming up but it's not drying
Exhaust full of lint. Vacuum into dryer exhaust as far as you can, Then clean out complete vent from dryer to outside. Any lint will catch moisture and clothes will not dry.
Jul 21, 2009 | Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Heating element stays on
stat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Mar 07, 2009 | Whirlpool LER7646J Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
119 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
