Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer not printing
Printer goes through the motions, but spits out completely blank paper.
I've put in new ink cartridges (twice) and still nothing.
Can you help?
  • newkirk1219 Jul 27, 2008
    Replace the black ink cartridge but the printer will not print. Tried the suggestion of holding the cancel and print buttons but that did not help.
  • Gary Oct 02, 2011
    You may have to re-install your printer software, then after doing that re-boot your computer. If that doesn`t work unplug your printer (both plugs), while unplugged re-boot computer,plug back in, re-install your printer software, re-boot again and try printing a test paper. Good luck.
    Scholar:
  • 96 Answers
Try this. Push the copy and cancel buttons together for about 3 seconds. Then release. The printer should push a blank piece of paper through. Try to print.
Posted on Jul 23, 2008
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Replaced ink cartridges, printer goes through all the motions, but paper comes out blank. I have done all the maintenance steps. What gives?
Cannon ink cartridges go into a print head. This is normally a removable box the ink cartridge sits in.
First remove the head and the cartridges from it. Now try this to clean the old ink off the print head, rub/soak the print head in alcohol. Make sure the print head is complete dry and place the ink back in it and return to the printer. Try to print a page, if you have the same results you need to replace the print head.
Jul 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
I bought lexmark 2200 all-in-one second hand.I've loaded software twice but still printing blank pages.It says both cartridges are full. Could this info be wrong? I hate to buy new cartridges if printer is...
Is this a genuine lexmark cartridge? If so, please take it out and use a tissue paper to cover the bottom part and give the cartridge a gentle shake.
Then clean away the ink and put it back in.
Aug 15, 2010 | Lexmark X2250 All-In-One InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer prints no ink.
probably you just replaced th "ink" but what you really need to replace is the "PRINTHEADS"
Put new printheads and printer will print like new again.
Sep 13, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Does not print
You have a defective printhead. Contact Kodak for a new one.
Feb 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP 7130 WILL NOT PRINT BLACK
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | HP Officejet 7130 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
167 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
