Question about Mitsubishi WS-65809 65" Rear Projection Television
The error codes...
Ok we did that.. It flashed 2 times then 3 times... It did it 3 or 4 times....
  • Anonymous Aug 20, 2008
    where would i find the horizontal output transistor
    Master:
  • 505 Answers
Its 90% defective Horizontal output transistor
Posted on Jul 18, 2008
  • Mitsubishi Master
  • 8,617 Answers
A 2 3 code means horizontal deflection has stopped thats what is most likely shutting down your set. The most probable cause for this would be a defective Horizontal output transistor.
Posted on Jul 17, 2008
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
My TV shuts off as soon as I turn it on...What is causing it to do this??
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
-The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
-The flashing then pauses for approximately 1/2 second.
-The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
-The Error Code is repeated a total of 5 times.
-Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
Self Diagnostic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Apr 08, 2010 | Haier 20" TV/DVD Combo
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Will not turn on
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
times.
Self Diagnosic Code Description
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv willnot turn on
times.
Mitsubishi WS-65809 65" Rear Projection Television Logo
172 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
