Question about Gateway FPD2275W LCD Monitor
Monitor will not go on
We ordered from best buy a 26inch lcd monitor plugged it in and it will simply not go on all connections seem ok then decided to put back the old one now that one will not go on. please not old one was working fine at time just wondering what are some of the rasons this will do this it also said something about resolution? and also said something like powermode?
    Novelist:
    Scholar:
  • 141 Answers
You need to take it back to Best Buy and have them test it. That's the least they can do for you! (lol)
It sounds possible could be your video, rather on-board or a card, since the old one is now not working either.
Could also be a memory issue.
Posted on Jul 18, 2008
Radiation lines scroll on monitor screen
Check and jiggle (yes, that's the technical term) the monitor cable at both ends to make sure the connection is tight. If this doesn't help, borrow a cable from another computer (or a friend) that you know works, and use that to connect the monitor to the computer. If the picture is no longer snowy, you have a bad cable; buy a replacement one from any number of dealers (I recommend http://www.discountcablestore.com/, they're just about the best prices anywhere, but if you don't feel comfortable ordering online, any store with an electronics department should have one.)
If it is still snowy, try plugging your computer into a different monitor and see if the picture is still snowy. If it isn't, then your monitor has probably gone bad; check it's warranty, and consider buying a replacement.
If it is still snowy, post back here with the name of your graphics card (in Windows, this can be found by pressing the Windows key and the R key at the same time, then typing in 'dxdiag' without the quotes, hitting Enter or OK, and looking at the 'Display' tab of the window that opens. If a warning message shows up about it being run for the first time, click OK or Yes.).
Mar 01, 2011 | Samsung SyncMaster 152 (Silver) 15" LCD...
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
How do I connect speakers to a hpl1706 monitor and what are the best cheap speakers for this?
I suggest optional HP Flat Panel Speaker best fit to your LCD Monitor. Easy Installation and connection, just simply connect the audio input jack to your PC's sound card (green color female jack)
Apr 10, 2010 | HP L1706 17" LCD Monitor
Monitor receives no signal from PC. Connections tested : OK
You should not need a driver for that. If there is a plug on the laptop to connect the monitor, simply plug it and reboot.
You probably need to use some key combination to activate the external display. Mostly "Fn" + one of the function keys (it will have a monitor shown on it).
May 15, 2009 | Averatec 4200 Notebook
Should i buy acer 2017 lcd monitor for playing games?
Good morning! if you decide to get an lcd i would suggest one with very 'low' response time. such as 8milliseconds or less, as it looks amazing nothing beats the richness of the colors in an lcd. best regards
May 07, 2009 | Acer AL2017 20" LCD Monitor
Shadows
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
Turns off when a signel is connected to it
Try to connect LCD to another computer.
If it is ok something then went wrong with your PC.
Either your display card defect or the CPU need to reinstall the OS (operating system).
Nov 19, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor doesn't work
When you got the pc, you should have been given a starter pack with some CD-ROM's in the pack, one of them should be the drives for the monitor, you might need to use anothermonitor to see the instructions, but the basic graphics card should power the monitor enough to set things up, until then you won't be able to adjust the settings.
Apr 17, 2007 | Kogi L7CH Monitor
Changing monitors
If the video cable will come out of the monitor the connector will look like the one that is connected to the back of your pc on the other end with 2 long screws. If its simply a wire straight in you cant remove it. If you mean the power cable, you will need the same 3 pin connector as a kettle has, or it will have a special connector which normally has a voltage regulator built in the plug
Oct 25, 2006 | Samtron 76df 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
