Question about Xerox Office Equipment & Supplies
Zerox workcenter m151 when i print i only get on both sies of page light coverage not readable copy if i copy with cover open i get two solid black strips do i neeed a new drum or is it something else thank you jerry
  • jerry20 Jul 18, 2008
    thank you
    I put in a new toner cartridge
    the only thing i have not changed its the drum
    I do not know if i should put one in or not
    I do not know if it might be the drum or if it is the optical
    when i use the drum cleaning the zerox model m151 I get a message printed on a sheet of paper telling me it was cleaned
    i just do not know what to do
  • 2,072 Answers
Your toner is empty and just not indicating it's empty.
There is a light sensor and windows through the cartridge. Sometimes there is a little ink left on the window and it doesn't report empty.
Posted on Jul 18, 2008
  • Rick Kasper Jul 18, 2008
    It obviously prints fine? When you run reports its not a problem I am assuming.
    If thats the case and print works fine, then you have a dirty scanner, or a failed scanner.The mirrors or lens is hazey and in need of cleaning.
    Sorry I misunderstood. I have been out of the office and not able to answer earlier.
    If you need directions how to disassemble the scanner and clean it let me know.
  • Rick Kasper Jul 19, 2008
    Your scanner needs to be cleaned or if that doesnt work it will need to be replaced.
    Let me know if you get this message please.
Not a copier guy here BUT came up with this
1) From here
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
Xerox printing all black pages
You have no light output. The system places a charge, the image will remove charge (without image processing, the system leaves full charge ) (removes charge where no image is if negative processing)
EX: a copier has platen closed makes a copy because the cover has a white surface the light is reflected and removes charge from Drum. If you make a copy with platen open out put will appear black. Charge was not erased, toner is attracted to charged area.
Most systems use a small wire to place charge, depending on what development (pos or neg) with broken wire will also result in either a black or blank output. I would look for a broken charge wire.
Mar 05, 2014 | Xerox Corporation Xerox ColorQube 8900X...
first you need to check below mentioned details..
1) remove usb cable and see it is stand by mode or not.
press power batten and then cancel batten hold the 3 sec and release at time... it automatically print one page. if you got this page it means there is no problem with printing...and check zerox also it is ok means it mens printer is working fine ..problem is drivers....
Feb 15, 2013 | Hewlett Packard Printing & Imaging HP...
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Too much ink to few padges printed
The 1000-1500 mark is usually just a guess - it usually assumes no more than 15% coverage of the page.  If you are printing out very large pictures (full page images) or are printing lots of a single color (green landscape images), then the ink will run out a LOT sooner.
May 27, 2009 | Office Equipment & Supplies
Too light of print
Blowing out dust is not a good idea. access to the laser optics is open on this machine, and you will only make the problem worse, by blowing dust and toner inside.
Dirty laser optics are the cause of our problem. The only way to solve is remove top cover of machine remove several wire connectors, remove cover of laser unit and clean all mirrors, motor, and reflectors.
Apr 02, 2009 | HP LaserJet 1200 Printer
Want to know toner yield for the Ricoh Aticio MP 6500
43,000 copies/bottle (based on 5% coverage). For the extremely low cost per page of toner usage, why bother with toner save - you lose substantial quality
Mar 26, 2009 | Ricoh Office Equipment & Supplies
Workcenter m151
Not enough information......
Does the problem when copying on the glass...through the document there part of the information you expect to see there with the black lines over the top, or JUST the black lines ?
Jul 17, 2008 | Xerox WorkCentre M123 Copier
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
