Question about Optoma HD72 Multimedia Projector
Projector problems Hi there. I have a problem with my Optoma hd70, after 1-2 hours it starts to flicker in colour shifting from blue, green etc. and after awhile it turns itself off. Its connected to my PC with a VGA-cable and to a DVD with HDMI. The standby/on led is green and the led for the lamp shines red. If i restart the projector it starts normal again. I have tried reset it in the menu. Is this the first signs that the lamp is "dying"? The lamphours is about 1700 hrs. Best regards, Christer Olsson.
  • FrustratedTC Nov 14, 2008
    Hello-
    I just bought a new Infocus 2102EP projector and connected it to my laptop. After some time (that length of time varies from 1-2 hrs to 30 minutes or even upon startup) the color of the projected image only (no color change is seen on the laptop screen) changes to blue-green only (no red or magenta). Thinking that the problem must be with the projector, I called Infocus' Tech Support and they told me that the problem must be either with the cable (VGA) or my laptop, not their projector since it is a DLP projector. Since I've used this laptop for other presentations and have not seen the problem, I decided to return the projector. Amazon sent me a new projector (and cable) one and, frustratingly, I have the same problem!
    I can't think what it could be. In my efforts to fix the problem, I've tried to change the NVIDIA settings on my computer. Strangely, when I click around within the NVIDIA control panel, the projected color sometimes changes (either returns to normal or from normal becomes blue-green). But, I haven't found a solution to the problem- the NVIDIA control panel seems to affect the color, but its never a permanent fix.
    Projector geniuses, your help would be much appreciated!
Hi, I have an Optoma EzPro 751 that had a similar problem, although it got progressively worse until it only took about 5 minutes to begin acting up. I was really frustrated, as the bulb only had around 600hrs at that point and the picture was bright. After some searching of forums like this, I found someone else with the same exact problem, but with a Dell projector (made by Optoma).
The culprit was LOTS of dust, built up on the circuitry, built up on the optics, built up everywhere! Solution: carefully open up the case and use canned air or an air compressor with a blow nozzle attachment. (warning-compressor air MUST be filtered first as it otherwise contains moisture and other harmful suspended contaminants)
I was at the end of my rope, and this really worked for my problem. It's worth a try, but BE CAREFUL! There are delicate parts in there you don't want to blast apart with air. If you use the cans, buy several as it took me quite a bit of blowing with a compressor regulated at 90psi to get it all out. Good luck!
-Paul
Posted on Aug 11, 2008
My optoma projector has a green tint
it may just need a service, as all DLP projectors need to be cleaned internally as well as LCD.
DLP projector images will flicker and lose colour also may shut down if it is very dusty inside.
Jan 28, 2013 | Optoma Office Equipment & Supplies
HD70 DLP Projector: The projector is used and about a year old. It cur...
Did this start occurring after you replaced the lamp?
The reason I ask is I had the same issue after changing the lamp and it was caused because when I took out the old lamp I noticed dust in the lamp housing which I attempted to blow away.
This caused the problem because some dust got further into the projector, specifically around the color wheel. I sorted it out by taking the projector apart following the instructions here:
http://tantht.blogspot.com/2009/02/how-to-remove-dust-blobs-from-optoma.html
(note my HD70 was out of warranty, if yours is not, I would recommend contacting Optoma to get it fixed).
Follow the above instructions to step 14 and then locate the color wheel which is at the front of the projector behind a dark gray, plastic type square shaped cover.
You have to be very careful here, but remove the color wheel (there is one screw holding it in place) - note it
May 18, 2010 | Optoma HD70 DLP Projector
Flickering image and green hue on Optoma HD200x
this happens to my hd20 sometimes. just happened on pc through hd20. when i turned it on said 30hz instead of 60hz. so i changed resolution down then back up to 1920x1080 and it is sorted.
irving6000
Apr 09, 2010 | Optoma HD20 DLP Projector
New Bulb (30 hrs). Screen flickers after 10 minutes, color changes with green tint, then bulb shuts off.
Hi, I had a similar problem - the screen flicked through blue, green and red sometimes with a slight ticking noise. The problem seems to be that the colour-wheel is getting stuck - the first time this happened I sent it back to optoma who gave it a clean - it has happened again since thouegh and I just took the case off (you'll be able to see the colour wheel under a black plastic flap - remove the flap) I then used a cotton bud (q-tip) and turned the colour wheel whilst lightly pressing the cotton bud against the wheel - I also gave everything a blast with a can of air. My HD72i is ceiling mounted - optoma suggested putting the hoover pipe across the vents every now and then to keep the dust down. Essentially it's dust that is stopping the movement of the colour wheel.
Hope this helps.
Jonathan
Oct 21, 2009 | Optoma HD72 Multimedia Projector
Optoma projector Ex350 connect to xbox360
buy a new projector i recommend sanyo projector specially model XT35... cause your projector is not compatible to your xbox.
Oct 06, 2009 | Optoma EP716 Multimedia Projector
1200MP DELL Projector flickering problem
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | Optoma HD70 DLP Projector
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Dan
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
I have the optoma h31 projector and the color turned purple. We assumed it was the bulb and put a new one in. The color is now still not right and the picture sorta bounces
I had a similar issue with my EP739, the problem would start after about 3 or 4 minutes and then get gradually worse and worse..
The most strange thing I noticed was that white looked fine. And if you opened the configuration menu in the projector it appeared that blue was labeled green and green blue..
Some sites suggested cleaning the machine of dust, which I tried using a can of compressed air... This did not fix the problem at first.. but when I had it apart I studied the colour wheel for a little while and wondered if some how the machine was synching to it incorrectly somehow.. So I blew out the colour wheel location sensor (It's kind of obvious being the only component mechanically connected to the color wheel. Much to my delight, this fixed the problem...
So my solution to the flickering / colour fading / colour swapping issue with DLP projectors was to clean out the dust from the colour wheel location sensor..
In fact, if I did it again, I would ONLY clean the sensor, and leave the rest of the dust alone. Blowing dust around has the potential to cause other issues, especially if it winds up inside the optics system.
- Nate
Apr 27, 2008 | Optoma H30 Multimedia Projector
Optoma HD72 Multimedia Projector Logo
396 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
