Because it is not starting, you should replace the Crankshaft sensor (above the oil filter, back of the engine)-it will cause a P0700-I have a 99 SL2, 178,000 miles
DTC) CODE # P0700....Transmission Control System (MIL Request)
Translation: Transmission Control Module (TCM) Malfunction or Failure.
P0700 Information Code
The Transaxle Control Module (TCM) monitors the malfunction of sensors
and actuators relating to transaxle control. If any malfunction is
detected, the TCM informs the PCM by sending a signal (P0700 code).
P0700 means that a code has been set in the TCM.
This code is for information ONLY. If this code is present, check for transaxle codes.
So basically, the P0700 code is telling you to check the TCM for a
transaxle DTC. The TCM can not turn on the check engine light so it has
the PCM do it. The dealer probably saw the code P0700 and went to the
TCM and pulled out the code stored there telling them the Transmission
Solenoid Assembly (TSA) is bad.
This is a good example of understanding what the codes actually mean.
If the manual you looked at said the TCM is bad and to replace the TCM
when you see a P0700, then it is wrong.
The code P0700 means a TCM module has failed, but I would start by checking trans fluid levels to ensure they are not low.
This code is for information ONLY. If this code is present, check for transaxle codes to further diagnose what is failing.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Hi friend,Diagnostic Trouble Code Table maybe can help you,good luck!
For the P0700 I would check your tps sensor first to make sure it is good. This is a common failure in this vehicle which can sometimes show as a transimission malfunction.
Hope this helps, if you want alot more info about jeeps goto www.cherokeeforum.com
