Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Printer Stopped What is a J2 Error? I replaced the toner cartridge with a new one and the J2 Error appears a few seconds after the copier has warmed up. A red light has been on between a squiggly on the left and a triangle on the right - I assumed this was a "toner low" indication and I continued to use the copier because there usually is weeks of toner left.
  • Jack 71708 May 11, 2010
    Accessed on-line manual for this copier @ the Xerox web site. J2 is for the J2 Drum Cartfidge that needed to be replaced. Called Xerox - Speaking to “Marty” in Dallas from Xerox @ 5:25 pm EDT Thursday, the “13R551” will be shipped today from Los Angeles and for $8.63 it will be Fed-Xed for delivery before 5:00 pm tomorrow, Friday. “Ain’t this a great country or what?” For a Total of $216.57 the cartridge was waiting for me when I got home Friday. I installed it and the Copier is working fine. All this happened is about a 24 hour period. They (Xerox) convinced me "BUY XEROX".
    President:
  • 2,072 Answers
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Posted on Jul 18, 2008
Toner exhausted and replace toner how can solve this error without replace new cartridge
When the toner cartridge is exhausted or empty then the printerwill not be able to print further documents or the prints will be very faint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 15, 2011 | Samsung SCX-4300 Monochrome Laser...
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
C0070 still appears
the toner housing sounds like its been turned by hand when the toner has been replaced, it is possible that the drive gears in the unit have been stripped(worst) or could be that the rotation locking mechanism has been dislodged and just needs repositioning
Jun 26, 2009 | Konica Minolta Office Equipment & Supplies
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
J2 Error on XD125F
With that machine, what frequently happens is the flag in the drum unit falls down during shipping and does not swipe the drum replacement switch.
You can do one of 2 things, Exchange the drum cartridge or, on the front of the cartridge you have to remove the green cover, Remove the clip and pop off the gear cluster. Then look at the one gear in particular that has a flag like protrusion. Rotate it so that it stops up and to the right, so that when you place the drum back into the machine it can rotate down and hit the switch that tells the machine you replaced the drum.
That flag only runs a half turn, one time at install. And if it has fallen in shipping hte J2 will not clear.
That is what has happened. It is pretty common.
Sep 17, 2008 | Xerox WorkCentre XD130DF Laser Printer
XEROX WORKCENTRE XL2120
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
J2 Error
check for a paper jam in the machine and in the paper tray, if no paper is found take out toner cartridge shake it slightly and reinstall. Also turn machine off & unplug. Let me know if you need more help.
Oct 26, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
321 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
