Question about Nokia N95 Cellular Phone
Answering a call
When i recieve a call the fone answers itself after only one ring, how can i fix this?
    Problem Solver:
  • 6 Answers
Your phone is on something called auto answer. Go to your menu, settings, call settings and select auto answer, and then turn it off.
Posted on Jul 29, 2008
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
My gigsate al285 not ringging for resiving the call what is the pr i need your answer soon pls
U can try a cold reboot that where u have the fone turn on
and then u take out the battary while the
fone is turn on it fixed many erorr.
if that dosent work u may have to send it back for a software reset
Jan 16, 2011 | AT&T Siemens S46 GSM Cellular Phone
Fax is trying to answer my phone
Check the settings of your fax. You have to set it on which ring you wish it to answer. You can't fax without having a hard line phone plugged in. Also, you must have a filter on your fax line if you use DSL.
Oct 13, 2009 | Computers & Internet
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Not recieving fax
Try This
Goto to Setup (on the printer) Fax settings Check The ECM(Error correction mode) : It should be off ; DRP(Distictive ring patern): ALL Rings; Rings to answer 2 (dedicated) ; 6 (Answering machine ); There should be no voice mail service activated otherwise you won't be able to recieve fax; Try getting fax it should work;
Regards
SOumajit
Aug 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
Fax and answring machine on same line
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Nov 19, 2008 | AT&T (1718B) Digital Answering Machine
Fax
you must to enter at menu or setup in your fax and turn on auto answer,and to chose number of ringing before fax answer
Feb 28, 2008 | Dell 962 Photo All-In-One InkJet Printer
Recieving / answering phone
i had the exact same problem. basically (sounds a bit weird) but it happens if you drop your fone and the only way to let people hear you again is by dropping it again! so whenever you drop your phone you have to drop it again to fix it.
Jun 14, 2006 | Sony Ericsson T610
Nokia N95 Cellular Phone Logo
262 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
