Question about HP LaserJet 2100 Printer
Problem. Help please
Our deparment got a hand me down printer with no manual. It won't print and the red light comes on by the triangle symbol. I haven't a clue what that means. Help please.
If the light is steady, the manual says possible problems are
  1. it is out of paper
  2. paper is jammed
  3. one of the doors is open
  4. the toner cartridge is missing
Posted on Jul 28, 2008
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Mar 27, 2013 | Dell 2230d Laser Printer
No magenta ink, just need to print in black but won't let me.
Hello.
Hold down the Stop/Reset Button (it has a red triangle on it) on your printer for 10 to 15 seconds until the light stops flashing.
This will disable the ink level monitoring for the empty cartridge, but be careful not to print with a completely empty cartridge, as this can burn out the print head.
Regards GM
Jul 29, 2011 | Canon PIXMA MP520 InkJet Printer
I have an HP Photosmart 7260 printer that my cousin gave to me used so I have no manual. I've replaced both ink cartridges and am trying to print. When I send the print job, a red light begins to flash...
Can you see any symbol when the red light flashes? or any message pops up on your computer? Since your problem's description isn't very specific, I am unable to assume myself. If cartridges are replaced with new ones and the problem persists, it's possible that there's paper jam or carriage jam or contacts on the printer is bad/dirty. While the machine is On, lift up the front access door and try moving the carriage manually. Please follow this LINK to clean the contacts.
Please post back with more specific details so that I can help you better. Good Luck.
Feb 18, 2011 | HP PhotoSmart 7260 InkJet Printer
My Dell 1130 Laser Printer has a red light flashing (triangle and <--> symbol). What does this mean?
Your toner chip page counter has to be reached on last point (run out). Normally one OEM toner cartridge chip can print 2.5k pages, after that cartridge has been locked (although it's remain toner) and red light will be blinking. So, you can't able to take print furthermore in this state. You need to change cartridge chip or you can contact me by my mobile: +91 9330033560 or write a mail to my email id: <e_postmaster@rediffmail.com> I have a solution for changing printer firmware which will make you printer permanent solution for taking print out without changing chip.
Feb 01, 2011 | Dell 1130 Laser Printer
Machine has an error code & won't print. We have no manual.
If the lamp is on solid that is a cancel job or reset printer indicator
If the lamp is blinking (flashing) that is the secondary Jam error meaning somewhere in the paper path is a jam. The lamp shoul dbe blinking in a sequense - that sequence indicates what are of the printer the jam is. So the lamp should blink a number of times, pause then blink the same number again.
1 blink - jam in feeder sensor
2 blink - jam in manual feed
3 blink - jam under toner
4 blink - jam in output are
5 blink - jam in tray 1
6 blink - jam in tray 2 (if present/option)
Sep 03, 2009 | IBM Infoprint 1412 Laser Printer
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
May 21, 2009 | Samsung ML-2510 Laser Printer
Sharp AL-1631 copier. Red flashing triangle no owners manual. Dosn't work. Help
Flashing triangle of dots? for your reference, this is, and always has been, the universal symbol for add toner.
...and here's your manual:
http://www.sharpusa.com/files/cop_man_AL1641CS_1631.pdf
Feb 25, 2009 | Sharp AL 1631 Copier
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
HP LaserJet 2100 Printer Logo
148 people viewed this question
Ben Johnson
