Question about Ricoh Aficio 450 Copier
Ricoh Aficio 450
Gentlemen: I have a functional problem on my Ricoh 450. Error message is SC730-00 (call for service). Am I able to repair myself?
Thanks for your assistance.
  • Ricoh Master
  • 2,794 Answers
Its coming from your finisher. Its a stapler error. Make sure the cartridge is in all the way. If you open the door make sure it is parked in the home position for you to access it.
If you changed the cartridge recently, make sure it is inserted all the way.
Posted on Jul 18, 2008
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
ERROR CODE E-5 HELP RICOH 4522
If you press the "." key you will get the last 2 digits to complete the error message. For example: "E542".
Whatever the result, 'E5xx' is always related to a fuser error; That means, you have a blown fuse, lamp, or thermistor, and the problem, and the service code can only be reset by a technician in service mode after the fault is fixed.
Nov 25, 2011 | Ricoh Aficio 450 Copier
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Poslem poveke stranici kopiranje se pojavuva kljuch so functional problems SC350-01.Aparat Ricoh 450.
sc 350 is the ID sensor error. clean the ID sensor and it should be fine. the ID sensor is located above the drum unit.
Oct 27, 2010 | Ricoh Aficio 450 Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Jun 25, 2009 | Ricoh Aficio 450 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 450 Copier Logo
173 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
