Question about Citizen Eco-Drive BL5180-57L Wrist Watch
Constant watch problem
My citizen eco-drive watch has been repaired 2x already and it has stopped working again. The crystal was cited as the source both times. Are they just not reliable. Are there any work arounds? I am tired of sending the watch out to CA only to have the same problem surface again. Any ideas?
  • 23 Answers
The Citizen Eco Drive watches use special recharchable batteries. Not all watch repair man understand this. If you are unlucky they tried to replace the battery with an ordinary one. Replaced crystal could be 2 things, logical is the timing quartz crystal was replaced by swapping out most of the electronics, second is they talked about the glass being replaced - I do not expect so. Call or email Citizen and explain; keep the watch handy so you can read them the numbers from the back.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Posted on Jun 25, 2009
Where can I get a new glass cover for a womans citizen eco drive watch ?
You can ship the watch back to Citizen and they will repair it . Go to their website to get the return information and the form for the repair request.
Jul 31, 2017 | Citizen Watches
I received watch for x mas and Sat 4/2 it stopped wound it and it stopped again 4/4 is it not getting enough light or do I have a bigger issue. Thanks
Eco-drive watches do not need winding or batteries, so if you are winding it to make it work, then it is not a true Eco-drive watch.
Apr 04, 2016 | Citizen Eco-Drive watch
Citizen eco drive stopped working
Bad capacitor (Titanium Ion Battery)... probably a $30 or so repair on a fine watch.
Feb 17, 2014 | Citizen Watches Citizen Atomic Perpetual...
Has stopped completly
Being an Eco drive watch it needs light to make it work. Place under a light source for a few hours an see if this works. If not it will need a new power cell, which is like a rechargeable battery for them. It will need to be purchased from citizen or suitable watch maker
Sep 30, 2013 | Citizen Eco-Drive Calibre 8700 Wrist Watch
My citizen eco drive just stopped working ,iv had it less than 6mnths
Eco-drives need to be exposed to light every day. To learn how to recharge your watch, you truly need to go to the following Citizen link:
http://www.citizenwatch.com/COA/English/rechargeguide.asp
Best regards!!
Aug 19, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Replacement mineral glass for Citizen Skyhawk AT
mcdevito75 here, Yes, there should be, look for a small watch repair shop in your area, for this crystal.
Jul 05, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Citizen eco drive watch doesn't work
My Citizen Red Arrow wristwatch which I purchased last Christmas has a blank display and won't reset . Any ideas would be appreciated
Nov 07, 2009 | Citizen Eco-Drive Modern Watch
Hi i have a eco drive watch and it stopped for more than a month now , how can i get it repaired
You do not need any repairs, just put your watch under the bright lamp for a couple of days and it will restart again. The best place would be window sill and plenty of sunshine.
Jan 20, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Condensation in crystal of eco watch
If there is water in the watch, it's going to quit working sooner or later. If sooner, then the watch (at least the back) will have to be opened anyway. If later, then there will likely be some rust that could cause the watch to never work again.
In the meantime, I'd advise putting the watch near some dry heat -- like a radiant room heater, or maybe a hair dryer. Don't "burn it up" trying to dry out the water. You don't want the crystal to melt, etc.
Water in a watch is bad. The best solution would be to have it repaired now.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco-Drive BL5180-57L Wrist Watch Logo
285 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
