According to page four of the manual linked below, you can simply hit START after selecting 1. Menu item, 2. Crust colour, 3. Loaf size, 4. Mix-ins, 5. START or Delay Start Timer.
If the bread machine is running, and you wish to overide the Delay Start Timer, NOTE down the other options selected for Bread Type, Crust Colour, Loaf Size and Mix-ins; then press and HOLD the STOP/PAUSE key for 3+ seconds to re-initiate the breadmaking process. Re-enter the options, and re-start the breadmaker using no Delay Start Timer (Hit START in step 5.) or enter a new Delay Start time and then hit start
1- DELAY TIMER HAS A SWITCH FUNCTION THAT HAS FAILED. 2- WASH INSIDE OF BREAD MAKER WITH COLD WATER, DRY, AND TRY TO SET TIMER. 3- BREAD MAKERS ARE NOT AS POPULAR AS THEY USE TO BE, AND ARE AVAILABLE AT USED ITEM STORES FOR 15 TO 25 DOLLARS.
as long as you don't use the time delay clock then it doesn't make any difference. If you use the delay program be sure to put the yeast in last right on top of the flour so it doesn't touch the liquid.
The battery is a back-up for the time display. Actual clock time, not the delay timer time. The battery also backs up any custom settings you created using the Homemade mode. Hope this helps.
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Are you making a different kind of bread than you did the first time?. If so some machine programs have a delay before they start kneading such as the whole wheat cycle. Also some machines delay the kneading process while they warm up the ingredients. If it is colder where you live now than itw was 6 days ago that could be a factor.
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
