Question about GE ZSC2001FSS Advantium Electric Single Oven
Advantium Turntable On and off
We have an advantium microwave/heat lamp oven. The turntable will sometimes turn and then stop or never turns at all. We replaced a broken shaft abour 6 or 7 months ago. The turntable seems to work fine with our the turntable tray out of the oven.
  • eweissb2 Aug 21, 2008
    Same exact problem - works without tray, but when I put in a tray it turns about half way around then stops.
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Advantium Turntable On and off
I would suspect the motor is failing, but it's also possible that you have an issue with a door switch or door switch mount, depending on your model number.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
rickzilla
  • 706 Answers
SOURCE: How to replace lower halogen light assembly, also, replacing turntable shaft
item 1474 is the turntable shaft and is GE # WB02X10624
You should be able to remove item 1476 and lift out the shaft to replace it..then reinstall item 1476 to lock it in place, Hope this helps ...
Posted on Sep 13, 2008
  • 202 Answers
SOURCE: the turntable in my GE Advantium ZSC1000 oven
test to see if you have power to the turntable motor ..if you have power then you have a bad turntable motor....
Posted on Mar 23, 2011
Do you have any directions to replace the upper heating element for a GE profile Advantium 120 model SCA100DBB93?
Hey Mary Lynn, .. with that unit not being manufactured any longer, it might be time to upgrade..IF you want to pursue replacement.. try here...
Ge Advantium Microwave Parts Fast Shipping RepairClinic com
Jun 19, 2017 | Ovens
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
My scb2001kss ge advantium no longer heats. it turns on and everything else works, but heat
check breakers for oven one side could of tripped if everything else works but the heat this is a normal problem the only other thing could be is that the controles are not working
Jan 26, 2010 | GE Profile Advantium SCB2001KSS Stainless...
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
Sep 12, 2008 | GE SCA2001FSS Advantium Electric Single...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Sparking when microwaving
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgh
Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
GE ZSC2001FSS Advantium Electric Single Oven Logo
239 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
