Used Toner Bottle Full - how do I empty it?
My Ricoh FT 7650 is reporting "Used Toner Bottle Full" I can't find it. Where is it and how do I get to it so I can empty it out and clean it?
  • 287 Answers
Hello Pete,
I have your bulletproof fix. Open the front door,and look at the far right bottom corner.You will see a piece of sheet metal about 3" by 6" that is locked down by a black plastic button that looks like an oversized thumb tack(if its still there). The black retainer holds the sheet metal slider in place. The sheet metal slider holds the used toner bottle in place.Remove the black plastic retainer and slide the sheet metal towards you.The sheet metal will actually have a hold on the waste toner bottle and so they both will come out together,as you will see when you pull it out. Empty the bottle into a trash bag (be careful, its not dangerous but can make one hell of mess). This machine uses an auger and tube assembly to deliver the used toner to the bottle. As the bottle reaches maximum capacity, the backpressure of trying to push more toner into a confined space causes a bind in the delivery system which trips a sensor(photo interruptor) and you get the message to empty the waste toner. So once the bottle is emptied you should be ok. Note: on rare occasions the tube and auger assembly(which became somewhat packed and therefore gave the message) will remain slightly bound even after the toner in the bottle is emptied.You might have to slide the waste toner bottle back in a couple of times to dislodge the clogged toner. In fact I have had to use a slight amount of "force" to jog the clog loose.Again this is rare. The copier should immediately recover once you put the bottle back and close the door. Another rarity can occur which will cause you to turn the copier off and back on in order for the copier to return to a ready condition. Have a fine day. ............SPINAL............
Posted on Jul 19, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Usually the used toner bottles are located in the back of the machine.
Go to the right side ( opposite sorte) on the bottom left see if there is a door ( usually held by a screw) remove, empty and return, it should clear out. There are two types of toner sensors one a trigger, so whenever it gets full the weight trips the sensor or two one that reads the level of how high it is, in this case most of the time you will need to replace the bottle.
Look for a white plastic kind of see trough container. Some times they putit in the Bcak of the machine so you may have to remove the back cover.
Posted on Jul 18, 2008
Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Feb 06, 2015 | Ricoh Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
The display panel on my Ricoh Aficio 1232C says "Used Toner bottle - 1 is full". What does this mean and what should I do? Rob Buckler
used toner bottle is full so you have to take it out and empty it. open the front cover, you will see one bottle in the middle and one lower down with 1 and 2 written on it. pull it out and empty it and fit it back.
Nov 30, 2010 | Ricoh Aficio 1232C Color Copier
The used toner bottle is full. Where is it
Open the right door,remove the transfre unit,remove the transfre belt unit.The waste toner collection bootle is located under transfer belt section.Remove 3 srews remove the case and use the vacuum cleaner to clean the waste toner empty.
Nov 24, 2009 | Ricoh Aficio 2035 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
How do i empty the used toner?
WAIT!!! Don't let Ricoh Steal your money...
You're going to get a little bit dirt with the trick, but there is no need to buy a empty waste toner bottel
Empty the waste toner bottle inside a plastic bag, the dust is kind of azard!!!, when the bottle is empty, clean it from the outside.
Place the bottle in the printer, (This is just for reference only), in the right side of the bottle you're going to see a plastic tag all dirty (You see it?) OK!!, remove the bottle from the printer, and then very carfully remove that plastic tag from the bottle taking care of not ripping it off, now clean the plastic tag, and put it in place again, and now your printer is ready to work!!!!!
Where's the trick?, The printer has a Photo sensor that is "looking" trugh this plastic tag, when the plastic tag is full of toner, the sensor can't get the signal, and then it says that the waste bottle is full..!!!
TONY!!
Feb 05, 2009 | Ricoh Aficio CL3500N Laser Printer
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
4,175 people viewed this question
k24674
jasbo
jasbo
