Question about HP Photosmart C3180 All-In-One InkJet Printer
ALL LED INDICATORS FLICKERS CONTINOUSLY ON INTIALIZING
  • Anonymous Feb 27, 2009
    I HAVE FITTED LED INDICATERS TO MY K5 750 AND THE RESISTORS BUT THEY JUST FLASH TO FAST ANY IDEAS
  • 26 Answers
Lols if all led indicator flickers it means hardware failure
Posted on Jul 18, 2008
All leds are blinking continously in Epson stylus cx 5500 printe
turn on/off, unplug, plug in2_bing.gif, should reset configs.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Have Beringer Europower PMH 1000
The clicking could be the protection relays kicking in and out.
Check your speaker cables for short circuits.
Also make sure that the load you are applying to it does not go below the minimum impedance which i believe is 4ohms on this unit.
Mar 10, 2009 | Behringer EUROPOWER EP2500 Amplifier
Blue LEDs flickering
Hi Altus , yes that is correct.
Which country are you in ? I will try and direct you to a repairer ?
Apr 29, 2008 | LG RD-JT91 Multimedia Projector
RD_JT 91/92 DLT Projector not switching on.
Hi Altus
This a common Mainboard failure on the LG JT91 if all the LED's flickers.
The good news is that it can be repaired. Much cheaper than replacement.
This will however have to be done by a Service Provider.
No DHCP or proxy DHCP were received
Sounds like a memory error. Have you tried to open up the box and reseat or replace the memory?
Oct 22, 2007 | Acer Altos G710 Server
Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
Dec 12, 2006 | Uniden TRU8865-2 Expandable System...
HP Photosmart C3180 All-In-One InkJet Printer Logo
70 people viewed this question
Seeker5211
Seeker5211
