Question about Microwave Ovens
Advantium Turntable On and off
The turnable in my advantium stops after turning for a short time in both the microwave and heat lamp mode. We had replaced a broken shaft about 7 months ago. It seems to work when the turntable tray is not on. The weight of the tray and food seems to contribute to the issue.
  • Microwave Ovens Master
  • 9,042 Answers
I would suspect the motor is failing, but it's also possible that you have an issue with a door switch or door switch mount, depending on your model number.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
Advantium arc
Unfortunately there is nothing you can do but to buy a new microwave oven Once it arcs it causes burns on and in the parts and most times cleaning does nothing
Sorry, good luck
Jan 24, 2014 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
The turntable of my Advantium microwave model SCA1000 has stopped turning. It will sometimes move very sluggish but when the plate is on will not turn at all. Can you tell me what needs to be done to fix...
The Turn Table motor needs to be replaced in the oven, this will require dis-assembly to get at the part, and please remember there is dangerous high voltage present if you are going to do the work yourself.
Jan 23, 2011 | GE Advantium 120 Convection/Microwave Oven
My advantium lights, turntable turns, timer works, appears to be working as usual, but does not heat..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Advantium microwave won't stop.
If it runs when the door is open it's a bad interlock assembly
Aug 31, 2009 | GE Advantium SCA2000B Microwave Oven
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium Microwave Oven
it is automatic, you can not turn it off. it is placed there so that the food you are heating is heated evenly. not on one side only.
tnx 4 using fixya.
drcool
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
Microwave Ovens Logo
121 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
