Question about Mitsubishi WD-57731 57" Projection HDTV
Wd57731 57 inch
Hi how do i check my lamp count?
    Sergeant:
  • 259 Answers
There is a service menu item, lamp timer.........can be reset.....on remote,
menu....2470.....enter. lamp timer item in option submenu.......good success, meder's tv service
Posted on Oct 11, 2012
    Master:
  • 505 Answers
Its impossible to tell
plz rate us mate
Posted on Jul 18, 2008
  • Mitsubishi Master
  • 8,617 Answers
There is no way to check it unfortunatly.
Posted on Jul 17, 2008
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
Green ligth comes on and then gose off, proceed by red ligth flashing.
Hi:
If you count the number of times the red light blinks before pausing and starts to cycle over again. This is the error code the unit is producing. Also if its been a while since you replaced the lamp then it may be time for a new one. Check the lamp housing and pull out the lamp it may be shattered. You can find the lamp area and installing instructions using you onwers manual.
Nov 10, 2010 | Sony KDS-50A2000 50" HDTV
I have a question, We bought our Hatchi 50 inch tv 3 years ago
The manufacturer normally doesn't count the lamp for the warranty, but call them definitely worth checking w/ the manufacturer. Otherwise if you need to buy a lamp you can try Discount-Merchant.com they have FREE trouble shooting available so you can check to make sure it is the lamp.
Apr 21, 2010 | Hitachi 50UX57B 50" Rear Projection...
Turn TV on. Turns self off. After many times, if picture comes on, Tv seems OK. All ready paid $350 to fix once 14 months ago.
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours, For what you discribe above the could be your problem, I did some research and you can find the best price for lamps http://www.discount-merchant.com/?click=52978 and they have free troubleshoooting
Regards
Nov 18, 2009 | Sony KP-51WS500 51" Rear Projection...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv turns off tne comes back on
Please count red light flash again.
5 times flash shows Lamp Error.
6 times flash shows No "DD 6V " output (G1 board) Its bit technical term.
Need fuhrer help, please Post it here.
Thank you.
Sep 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Dell 3200 Projector
Hi Tara
This normally indicates that the lamp will need replacement.
The Ibook and this Projector are compatible as long as you run a Microsoft operating system i.e. Windows 98' and higher.
When replacing the lamp , you can just as well clean out the Projector - this is quite important as it prolongs the life of your lamp.
May 18, 2008 | Dell 3200MP Multimedia Projector
Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
Hi Mac
Yes you can just take out the old lamp and install the new one in your existing lamp bracket. Simply unscrew , replace and screw back in.
Apr 12, 2008 | Panasonic (ET-LA995) Projector Lamp for...
Lamp didnt strike
Hi there
You should reset the lamp timer as this LCD Projector's counter counts down the hours and will not fire up if this has not been done.
If you have reset the lamp timer and the problem stil occurs , you'll have to replace the Ballastboard ( lamp's powersupply )
Dec 01, 2007 | InFocus LP 600 Multimedia Projector
Mitsubishi WD-57731 57" Projection HDTV Logo
307 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
