Question about Akai LCT3201TD 32 in. LCD Television
Fujitsu plasma display model :pds5001e-h
Hi dear
Condition:
Tv is on and led stnd-by is green. but it doesn’t have pic and light . when push the wide- mode or menu button, light in the some side of the panel comes and change . but the pic doest mean & pic isn’t describable. only line , line.
Symptom: course location
In the bourd scan no: TNPA1922 = R6501=22 OHM burned out. after change that , tv turned off , and led stnd-by ,red flashing .
Please guidance me
Best regards
hamid
  • 5 Answers
SOURCE: TV Won't come on...
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
SOURCE: Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
Posted on Nov 03, 2008
SOURCE: Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Posted on Nov 21, 2008
skotkolr
  • 558 Answers
SOURCE: akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Posted on Apr 05, 2009
SOURCE: Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Posted on Apr 28, 2009
Fujitsu 42 wide plasma tv No sound & No picture Only red LED light flashes Model no : PDS4233E-H
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 23, 2015 | Fujitsu Televison & Video
I have a 42 " Phillips with no pic and no sound. I've replaced the Power Board and CT Board tht corrected the error blinking lights but still have the problem My Light stays solid green and I
Dear Mate
Please share us the Model # and Is that is the Plasma LCD or LED. And tell us Is your`s TV is stay on stand by or its green LED is stable.With No video and sound.
Dec 11, 2014 | Televison & Video
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
Flashing red light no screen fujitsu plasma
This is a common complaint with Fujitsu plasma displays with a few years age. It is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Jun 04, 2009 | Fujitsu Plasmavision 42" TV
Broken plasma screen
You need your Tv product code wich is located in the back of the TV next to the serial number.
you can get one directly from LG ($500-$800) or you can try EBAY, look for a TV non working with a good panel, it doesn´t matter why is not working as long as the panel is in good condition, the price range is wide but you can get one for $150-$250.
And no you can not use any 42" plasma.
May 16, 2009 | LG 42PC5D Television
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu 42" Plasma Display shuts off after 20 minutes
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Oct 21, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Akai LCT3201TD 32 in. LCD Television Logo
180 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
