Question about Cameras
Non Displaying of recorded footage
On My JVC Cam Corder it is now working however if put a mini tape in that has footage on will not display only get a blue screen - even with new tape & recording new stuff still will not display
  • PaulKay Jul 17, 2008
    Have put in a new blank tape & recorded something still does not display
  • Cameras Master
  • 6,487 Answers
If that's the case its really a problem with the video reader of the unit..
You can call JVC for some help about this or have it replace if its still under warranty..
Good luck.........
Posted on Jul 17, 2008
    Guru:
  • 1,894 Answers
Did you perform a dry run?
  • 13,433 Answers
If you put in a empty tape and record something to it does the same problem happen?
Would seem a like a problem in the reader.
  • Ekse Jul 17, 2008
    Ok, its clearly a issue in the tape reader / writer and or components there. Do you have warranty on this camcorder? if not you can send it to jvc for service
    http://www.jvcservice.com/Service/
I can't get tape out of cam corder
Let me know the error message. Go down further on the error message check for numeric code. If you see ''02". I'm sorry you need a qualified personnel to do the job. if it shows "03" keep the cassette door open(5 sec or more and make sure to put power on it) and wait until it open.If it ejected, try with another tape, it could be your tape causes problem. Good luck
Dec 31, 2009 | JVC GR-D290 Mini DV Digital Camcorder
My JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
my JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
Dec 24, 2009 | JVC HR-DVS3 Mini DV/S-VHS VCR
My jvc dv mini cam messes up the tape
put cam in for professional service - either the head needs replacing (worn) or the cassette cage is warped and in need of realignment.
Jul 16, 2009 | JVC GR-DF470 Mini DV Digital Camcorder
Does this cam, play the mini dv tapes????
If you are referring to the JVC GR-DVL520, yes it does play Mini DV tapes, as well as records to them. It will not play Mini DV tapes that were recorded on an HDV camera. HDV is used by any Mini DV camera that records HD video.
Jun 24, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
Software needed to download JVC GR-DVL707
most cam corders either have cables that come with it that will plug into your vcr or you will need a firewire connector ( if you post back with make and model of your cam corder ) you should be able to go from there.
The manuals should tell you how.
Generally speaking a firewire cable should allow you to do it.
Apr 11, 2009 | JVC DR-MV7 DVD Recorder/VCR
Camera won't record a D comes on screen and eject tape comes up.
I have a cam corder model VP-D361 PAL, since i brought i could not use it even a single time, for the past 2 yrs it was kept as it was brought in packed condition, i was using other cam corder of jvc, when i opened and start using it, i found a triangle and a D on the screen, several attepts made by taking out battery, and casset. but still same thing appears,(AFTER REFERING TO USERS MANUAL) it may be a simple problem, or a defective one, since brought a single minute is also not used, kindly help me to solve this problem from a local serviceing centre.at mumbai, india.
My address as below,
K.J.SEBASTIAN
BLDG NO. 7, FLAT NO. 29
BORLA CO OP HSG SOC
DR.C.G.ROAD
CHEMBUR, MUMBAI- 400074
TEL NO. 91-22-2520 5842
MNO: 9892004970,9987904458
Jan 18, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Help meeee pls! JVC mini DV cam problems
just joking althoe macs are crap tho,you need a firewire cable and firewire support on your mac its that easy,you just plug in and the pc does the rest,not sure about mac thoe cause there crap
Jan 03, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
