Question about Microsoft Xbox 360 Console
FLASHING RED LIGHTS 1,2 AND 3
MY XBOX STARTED FLASHING RED LIGHTS 1,2 AND 3 AND IT DOESNT SHOW ANY DISPLAY AT ALL,ANY HELP WOULD BE GREATLY APPRECIATED.THANKS
  • pixieblu Jul 17, 2008
    flashing red light
  • 550 Answers
Red ring of death
microsoft has a recal and repair for this failure, contact 1 888 4my xbox and begin the process, warranty has been extended for this fault only, many xboxes have been repaired more than once.
Posted on Jul 17, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
after turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Jul 17, 2009 | Microsoft Xbox 360 Console
My xbox 360 has the third player light flashing red.
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
You should still be under warranty, follow the above url, and get a repair request in, it should be no charge.
Dec 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 wont read games
You should send the xbox in call 1-800-4myxbox mine started to do that right before it got the red ring of death(three flashing red lights)
Aug 27, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Lower right red light flashing with error e74 on screen
lower right is a hard drive failure> Take the HD off and try to play without it. Then put it back on.
Jun 28, 2008 | Microsoft Xbox 360 Console
Red lights keep showing on xbox 360
How many red lights show up. When this happens, does your XBOX freeze up? Are they flashing? Do you have anything stacked on toip of the console? IS it vertical or horizontal? Let us know and maybe we can help you.
Thanks,
Jun 01, 2008 | Video Game Consoles & Games
Xbox 360
http://www.360-hq.com/xbox-tutorials-23.html
Go here to answer all your question. I promise you.
Billy D
Apr 25, 2008 | Microsoft Xbox 360 Console
3 flashing red lighs??
3 red lights is the red ring of death your system has basically melted. your gpu overheated and is now not working. If your system is under warrany i would send it in and get it replaced Call MS for that.
If you bought it from like best buy with a replacement plan they will give you the purchase price back and you can do what you want with it.
Dec 17, 2007 | Microsoft Xbox 360 Console
Xbox 360
Hi, I hope something from below is useful to you...
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful in any way, please rate! Thanks
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
