Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Cd rom not opening
Whenever I push the button to eject/open the cd rom it does not open...you can hear it tyring to do so but it never actually opens.
  • 781 Answers
You may have something stuck in it.
try a long needle and insert it into a small hole on the front of cd when you do it should go in about 2 inches and stop press it in and cd should open check for anything that could be blocking it
Posted on Jul 17, 2008
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Acer aspire desktop cd rom will not open. When button is pressed, a nois can be heard but tray does not open.
It must be hardware problem with the CD rom. There are few gears inside the unit with some plastic levers that regulate opening and closing of the Tray. If the problem persists, you will need to repair or replace the CD rom. In the meantime, as a temporary solution, straighten a paper clip (a a long needle), push in through the tiny hole just below the tray while you press the eject (Open) button. You'll need to press inside the pin/clip with possible force and it will automatically eject out. Push in the pin/needle straight, you don't need to find anything inside the hole, just push it straight in.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 09, 2011 | Computers & Internet
Cd rom drawer on dell laptop won't open
hello, have you tried going into "My Computer" then right clicking on cd drive and click "Eject"? if not, try that.
if you have then take a thin paper clip open up one side of it so its straight.
After you have paper clip straighten up look carefully around the cd rom's eject button and you will notice a tiny hole.
Take the paper clip and keeping it straight slowly and gently insert in the hole and soon you will feel little resistance push it a little bit more and that should eject your CD rom.
if it opens up leave the cd rom open and reboot your laptop once and see if your drive now work normally and ejects the way it should?
hope this helps, post back if you have issues.
Kind regards,
Amar Sondhi
Jan 22, 2010 | Dell Inspiron™ 600M PC Notebook
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
The door on my cd rom cant not open when i eject, i dont hear the motor but the light shine just at start up
Look on the front of your cd-rom, there should be a small hole somewhere just under the tray portion. Turn off your machine (to avoid possible short-circuit issues) and use a thin piece of wire (ie: a straightened paper clip) and insert it into this hole. Push it gently, you will be able to feel the unit unlocking itself and the tray will open slightly. Now you can use your fingers to pull the tray open. Be gentle when opening, you don't want to mess up the gearing.
Oct 07, 2009 | Computers & Internet
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
The cd door does,nt open
Make sure you feel some resistance when pushing, also try by going to My Computer, righ-click the CDRom and select eject (in case the eject button is broken.
If you hear bad noises, you'll need to replace the CDRom
Mar 29, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
