Question about Microwave Ovens
My General Electric Spacesaver Microwave is not rotating and makes a clicking noise instead.
  • Microwave Ovens Master
  • 9,098 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
General Electric Spacesaver II JEM31E001 microwave light bulb....Burned out. removed outer side panel door and removed burned out bulb and can't find replacement can you advise. Is it safe to use the...
These are very standard appliance globes and your local hardware store can tell you which one if you take the blown one with you.
But if you want to order one you can do so from this online site.
Aug 19, 2014 | Microwave Ovens
What is the loud noise?
What kind of noise? Is it high speed fan? or rotating motor? Please describe!
May 02, 2014 | General Electric Ge SCB2000F 950 Watts...
Light's on, plate rotates, no heat
When the microwave works properly but just doesn't heat, then the magnetron is bad and will need to be replaced. You can get the part and the diagram at partselect . com or repairclinic . com
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My spacesaver microwave no longer will heat anything. It makes a different noise when it turns on. All the front pane info works well. Thoughts?
heatman101
kgll
Apr 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Jul 15, 2009 | General Electric Microwave Oven
Microwave no longer heats; makes no sound or buzzing noise
hi..it sounds like a magnetron problem.It might have
got into damage.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Read the question
Dear FixYa:
Just to let you know, I'm a general contractor in the state of michigan.And after I didn't hear from you
I just made a phone call to reasure myself on my question, because it's been a while since I installed
kitchen cabnits.Almost every spacesaver cord is located on righthand side.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
103 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
