Question about Dryers
When vented outside the clothes take 3 times the length of time to dry - how come? The vent is not plugged.
    Genius:
  • 1,028 Answers
Are you sure not plugged? look behind dryer is vent hose flattened to verify remove hose from dryer and try a load may get warm and some lint but this will resolve vent issue ..also if that is ge electric dryer element is double strung and 1 string may be burned out
Posted on Jul 17, 2008
LONG DRYING TIME
Most likely the vent is plugged - check the vent hose (usually start at the outside location & work back to dryer). If hose is not clogged, unplug dryer, remove vent hose from back of dryer and check there.
Aug 02, 2012 | Roper REX4634KQ Electric Dryer
My clothes come out wet after running for a length of time but they are hot
You have an vent issue..If the clothes are hot but not drying your not getting proper air circulation, you need airflow thru the unit to help remove the moisture from the clothing other wise you end up with warm moist clothing... Start unit and go outside to where the dryer vent comes thru the wall and check the airflow with your hand ,you should feel a good flow of warm air. If not some where between the unit and the vent their is a restriction either in the flex duct or the duct work in the wall which will need cleaned out before the clothes will dry in a normal time frame..Plus it cost a lot to run the dryer 2 or 3 cycles to dry clothes Hope this helps Good Luck
Aug 26, 2010 | Maytag Dryers
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Whirlpool dryer, it takes 2 or 3 cycles to dry a full load, the clothes are warm and when I disconnect the rear exhaust and turn it on it blows pretty good, it never took so long to dry the clothes
check the vent hose to the outside,especially if there's been siding installed on the house and the vent has one of those plastic guards by the outside exhaust,for keeping birds out,this can plug around the vent and build up with wet lint,run it without the hose on and see if drying time comes down to normal again,then you know the outside vent is the problem
Jan 26, 2010 | Dryers
Dryer will not dry clothes on the first time drying
if it is drying after two loadsthen you probably have a vent is clogged or slow due to a long length
if you go to where your dryer exhaust outside of the house you should feel good airflow,, it should almost move your hand type of air noit jsut a wind
Nov 02, 2009 | Dryers
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
Dryer is not drying correctly
ck vent system to outside ck for crimped vent hose on back or plugged vent to outside ..if burner ignites but fails or is slow to reignite suspect the coils on burner (the 2 black things with wires attached)
Aug 20, 2008 | Estate TGDS840JQ Gas Dryer
Dryers Logo
Top Dryers Experts
