Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printer dead Hi, Periodically, my printer would make a loud noise when it's turned on, and it would not work. But, this time when we turned it on, it just simply dead except there's a black line appeared on the LCD. We unplugged and plugged it again at different places, yet, it appeared the same. We've used this printer a little less than 3 years. Could you please tell me what to do? Thank you Li Chen
Remove the cartridges and then pull out the print head. Look on the bottom for burned out circuit traces. Canon & HP printers (and some others) are designed to "zap" the printheads with a high current pulse that gradually destroys the printhead circuitry. This is to keep you coming back for more. These guys are greedy beyond belief! If your Canon worked for 3 years consider yourself lucky. This is not the only solution but it is definitely one which applies to this issue. The loud noise is not necessarily related to the black line/bad printhead problem.
Posted on Jul 29, 2008
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN NOT COPY OR PRINT
Hi Patience .
Have you got anything on the display ?
Any error codes ?
Jun 27, 2016 | Sharp Office Equipment & Supplies
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
MY DRYER HAS STARTED TO HAVE A KNOCKING SOUND ON ALL SETTINGS PERIODICALLY DURING THE DRYING CYCLE. IT SOUNDS JUST LIKE SOMEONE KNOCKING ON FRONT DOOR OR LIKE A SHOE BANGING AROUND IN DRYER. MAYBE NOT...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Fisher and Paykel DEGX2 Dryer
Loud grinding noise. Paper only coming half way out then getting Jam notice. Loud grinding is very loud.
Hi
Grinding noises indicate either gears that are self destructing or something is stuck inside. Take out the cartridge(s), remove the paper and all the plastic that comes off. Unplug the cables. Now lift the printer, turn upside down and shake. If there are broken gears a local repair shop might try to fix it but most stores refrain from this.
Aug 05, 2009 | Dell 1600n All-In-One Laser Printer
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
LOUD NOISE
Hard to tell without hearing it. But, if it is doing it all the time it is turned on but not in use most of the time that would be a fan making the noise. The other suspect would be a fault toner cartridge or the fuser. you may need to have a tech look at this.
Hope that helps...
Jun 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Sharp CVP10MX started to make strange noise periodically
What type of noise. Fan noise or compressor noise?
Aug 25, 2007 | Sharp CV-P10MX Air Conditioner
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
Corne Viljoen
