Question about JVC Audio Players & Recorders
I have a JVC Ultra Compact Component System, the FS-2000 which will not play. i.e. the turntable will not spin. The button on the handheld will open and close the top, but when I then press CD, nothing happens.
  • nativetexan1 Jul 17, 2008
    You asked whether I could hear the CD spinning. The answer is no and I can see thru the transparent cover that the CD is not spinning.
    I have a JVC Ultra Compact Component System, the FS-2000, which will not play. i.e. the turntable can be seen on top beneath the clear door and it does not spin when I press the CD button on the handheld remote. There is no "play" button on the unit nor on the remote.
  • 6,487 Answers
Your first job is to open up the case of your CD player. This will be more or less difficult depending on the type of device. If you are lucky and have a Hi-Fi separate type device then it will be pretty simple; if you have a mini or midi-system with a built in CD player this could be trickier. Fixing portable CD players is probably only for the uber-patient as it is likely to be very fiddly. The main thing required here is patience and a methodical approach. As you remove screws put them somewhere safe; line them up in the order in which you removed them, or make notes of what goes where. You may reach a point where you think you have taken all the screws out but you still can't get into the case. Here, patience is still the key. Check under stickers for hidden screws or clips. Try and work out where the case is held together. Use the minimum force possible at all times. Now, assuming you have managed to get into the case successfully, and have got access to the CD player we can continue. By now you will probably be able to see the CD tray (the bit that holds the disk) and also some kind of arm which hovers over the disk when the tray is closed. There will usually be a small motor for moving the lens over the disk, and attached to this or nearby there is typically a small circuit board. On this board, or in any case rather close to the read head there can usually be found a small potentiometer . This will usually be a small square component with a plastic disk on top, and this disk will have a slot which is designed to take a small flat head screwdriver. This is what we will be adjusting. However, before doing this it is advisable to use an indelible marker pen (magic marker) to mark the current position of the Potentiometer, so that it can be returned to its original position if necessary. With this done then we are ready to start fixing your CD player. This is essentially a trial and error process. You make a small adjustment to the position of the potentiometer, then try the CD player and see if it is improved. In my experience generally only small adjustments (less than plus/minus 30 degrees of rotation) are usually necessary. Depending on how comfortable you are working with electrical devices there are different ways of going through this trial and error process. If you are unsure of yourself or particularly safety conscious then will probably want to put the case back on the CD player each time you test it because you will probably have to plug it in to do this. However, as you have probably guessed it is not necessary to put all the screws back in. If you are a little more comfortable with electrical devices, e.g. you're the kind of person who never puts the sides on the case of their PC, then you may want to do the testing without putting the case back on the CD player. Obviously, this requires a good deal more caution, but it also makes the whole process quicker. While the device is plugged in, be sure to touch only the player's play and stop/eject buttons, unplugging the device again before making any adjustments. Be sure to keep hands and tools away from the player's power supply unit (PSU)/transformer (if you don't know how to identify this then you had better close the case between tries). Also be aware that the PSU can store power for some time, so it is advisable to leave the unit unplugged for a while between attempts, and not to touch the PSU. After a few attempts it should be possible to find a position of the potentiometer (the little adjustable thing with the slot in the top) where the CD player recognises disks again and plays them without skipping. If, this is the case, then congratulations, you've fixed your CD player. Simply put the case back on and you are ready to rock.
Hope that helps.........
Posted on Jul 17, 2008
  • JVC Master
  • 13,433 Answers
Service required or you could replace the faulty parts, motor, lens and related. maybe a circuitboard issue, hard to say I suggest you have to tested by a pro.
  • 2,335 Answers
If the CD tray closes and opens properly, that means there's a hardware malfunction inside your receiver and will need to be service.
How old is your FS 2000 system?
    Master:
  • 555 Answers
It sounds like the stepper motor for the spindle has quit.
    Guru:
  • 1,894 Answers
Do you hear the CD spinning inside the unit?
The disc played all the way thru to last song-then sound cut out-came back & a 'strange motorized' sound ...put in another disc..-no sound but that strange noise 'like a warped something or...
The problem is the pladder motor that the cd disc sits on, the bearing in the motor is seized or the lubricant has dried out. In order to fix the issue the entire assembly must be replaced or the component stereo. The motor is built in such a way it can not be directly serviced.
Jan 08, 2011 | Audio Players & Recorders
Won't power on
I had the same problem. I just took it into a certified repair place. cost me 50 bucks to learn what part needed to be replaced and that it isn't available any more. Recyle it.
Nov 07, 2009 | JVC FS-2000 Shelf System
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Dec 08, 2008 | Audio Players & Recorders
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
FS-SD5
Its a good possibility that the turntable that the cd sits on is pushed down or up from where its suppose to be as if the laser cant focus on the disc the motor wont spin.There could also be a bad spindle motor as these do go bad or the motor driver ic is defective. see if you can somehow see the lens when the disc is inserted if you can see the lens moving up and down it is one of thoses problems I described are the cause, or worse case is a defective laser Pick-up assy. Good luck. good luck
Apr 15, 2006 | JVC FS-SD5 Shelf System
95 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
