Question about GE JGBP32WEFWW Gas Kitchen Range
GAS STOVE PROBLEM WITH OVEN ON "BAKE."
WHEN OVEN IS ON "BAKE", IT WILL NOT GO OVER 100 DEGREES AND A LIGHT THAT SAYS "ON" COMES ON AND WILL NOT GO OFF. NO MATTER WHAT YOU SET OVEN ON, IT WILL NOT GO OVER 100 DEGREES AND THE "ON" LIGHT STAYS ON.
  • 93 Answers
Check ignitor. It has to pull enough amps for the gas safety valve to open and light the oven.
Posted on Jul 17, 2008
Stove top burners work but when the oven is turned on it looks like the pilot light will glow but will not ignite the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Gene...OldTech2332
Aug 22, 2011 | Maytag CWG3100A Gas Single Oven
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
Whirlpool M# SF330PEWW3 ignitor comes on, but there is no gas for the oven to light. Stove top works fine.
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when set to bake ignitor by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than that replace bake ignitor. If you dont have amp meter take my word for it since in my 30 years appliance repair career i have seen when the ignitor comes on, that it's weak and found it to be the problem 100% of the time
Jul 31, 2011 | Ovens
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Gas Oven doesn't work under 450 degrees
most common issue is a bad bake ignitor, easy fix, probalby about $75, located on the side of the bake burner, simple to replace a few screws and 2 wires
Nov 17, 2008 | GE JGRP17 Gas Single Oven
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Oven won't heat
This could be the ignitor. The ignitor is located under the bottom of your oven. you get to it from the inside of the oven. A quick check though is to set the oven to bake and wait about 30 seconds and see if you can see a faint orange glow from the bottom inside of the oven. If you do then your ignitor is probably working ok and the problem lies somewhere else.
Apr 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP32WEFWW Gas Kitchen Range Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
