If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink wastepad replacement, if you want your printer to work again. There are two ways to reset the Canon MP830 printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using Mptool Software to reset Canon MP830 Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
SOURCE: error 5B00 and don't know how to fix it.
Error 5B00 refers to the waste ink absorption pads.
Inkjet printers have a fibrous pad inside them that collects the waste
ink from cleaning the print head. Over time, this pad fills up with ink
and can no longer hold any more. When this occurs, the printer
indicates error 5B00.
Replacing
the waste ink absorption pads is something an authorized canon service
facility can take care of for you.
SOURCE: i have the error code 5b00 on my canon i905d. please help
The error code can only be reset by using diagnostic routines only available to canon shops.
SOURCE: Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
SOURCE: how to reset canon pixma
The waste ink absorber is full and is triggering error 5B00. To reset the error you need to replace the ink absorber. You may find a cheaper ink absorber kit on Ebay or Amazon.
