Question about Hotpoint BWM12 Front Load Washer
Dial keeps turning on machine
I have unscrewed the black cap at the bottom of the machine to check for coins and gunk etc there does not appear to be any obstruction and the pump appears to be working ok.i switch off the machine and put it onto spin and that seems fine (pumping water out). when i reset everthing again to wash, after a few minutes the dial turns on its own again.........Please help.
Machine wont operate when dial is at rinse
Posted on Jul 19, 2008
My pump as a code dp2 just what problem?? Of that code appear
Pump could be just stuck . Unscrew filter on front bottom of wm then clean out any fluff ,muck,coins ,hair clips etc
Aug 11, 2014 | Washing Machines
My samsung top loader will only drain
Very easy repair. By dropping the hose gravity takes over allowing the water to run out. The buzzing noise is the propeller on your pump jammed.(Brawires,coins,hairpins) < common causes.. STEP 1:Drop hose down to remove water from machine STEP 2:Lean machine forward on a 45,rest machine on a chair. STEP 3:Bottom left of machine is a round black cap,remove the cap(turn anti clockwise) STEP 4: Put your fingers in the pump and pull out the coins,hairpins etc from pump. STEP 5:Turn propeller to make sure it turns freely,put the round cap back on then your done. Thanks
Jun 20, 2012 | Washing Machines
Just started clicking. No action. Water will not
Locate the pump cover at the bottom, front of w/m. Pry the round cap out from the top with a small screw driver and unscrew the cap anticlockwise.
Clean the inside of coins, bits of cloth etc. This may solve your problem.
May 04, 2010 | Whirlpool GHW9200L Front Load Washer
Why washer won't drain water
take the front cover off at the bottom of the machine. There is a filter cap that you unscrew that gets clogged with coins, etc. Put a towel or two down before unscrewing the cap. I never found this in the owners manual
Sep 21, 2009 | Frigidaire GLTF2940ES Front Load Washer
The water inlet does not stop during the entire cycle of washing in our NA F70GS Panasonic washing Machine. How to solve this problem?
Its simple..just follow step by step as below:-
  1. Switch off and unconnected both power & water supply.
  2. Lay the unit with the back side facing up.
  3. remove the back & bottom panel
  4. you will see the valve on the bottom tub.
  5. Unscrew the valve cap.
  6. Dismantle the valve by release the connector between steel bracket & hook (white plastic 'T' shape) using small 'playar'
  7. Then you will see a 20 cents coin ( keep into your tabung gajah)
  8. Use the old toothbrush to clean the black rubber valve.
  9. Assemble everything.
  10. Thats all.
Sep 06, 2009 | Washing Machines
Dial keeps spinning
I have an Ariston Margherita AL128 and the same problem happened. The dial keeps on turning and the operation does not finish at all. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manual once in a while, it does help! I lost mine but was able to download a copy from the net.
Feb 01, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
I have an Ariston Magherita 2000 it stops and the dial keeps going around when it gets to the spin. If I then put it back on spin it will not drain the water out. If I empty the machine and then put a...
Yo!
unplug machine from power.
pull the front panel off of the machine its at the bottom, kind of snaps off bottom first then top eases out, anyway becareful as it is pretty fragile plastic.
On right hand side unscrew filter cap - prepare for lots of water that really stinks to pour out. Cap can be a fiddle but does release after unscrewing anti clock wise.
Put fingers in and clear out any blockages you can see, mine was a 1 pence peice and a hair tie. Put back together and it should be ok.
Jan 01, 2009 | Ariston Technologies Ariston AWD12 Front...
Programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Dec 18, 2007 | Hotpoint BWM12 Front Load Washer
Dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Jun 15, 2006 | Ariston Technologies AWD121WH
Hotpoint BWM12 Front Load Washer Logo
158 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
