Question about Sharp AL 1631 Copier
Jammed paper Hi, I have a problem with my copier. The paper always jammed and I don't know how to fix it. The copier is sharp 1631 grayscale. I tried to fix it but I wasn't successful. need your help.
  • cnjsdaddy Jul 18, 2008
    my paper is getting jammed in the rollers after the copy proccess. There is something under those rollers that is very very hot
    any ideas?
    Thanks in advance
    Bill
    It also sounds like there is a gera stripping sound as the paper is trying to go through the rollers
    Scholar:
  • 53 Answers
If it gets to the "hot bit" rollers, then stops, you may have a broken fuser heat roll drive gear. The gear is available as a spare part from your Sharp dealer for around $7.You will have to dismantle the fuser assembly to fit it...that might be your biggest problem!
Posted on Jul 19, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Where is it jamming ? pick up, on the side in the fuser where it gets hot???
Posted on Jul 18, 2008
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
I had a jam in the paper try bypass, removed the jam, but the indicator light continues to blink. What's going on and how do i fix it?
open and close all doors on the copier ending with the front and side one.
make sure it is indicating a jam and not asking for paper in the bypass tray
Good Luck
Jan 15, 2010 | Sharp AL 1631 Copier
A loud clicking sound
This means that a gear is jammed or broken somewhere. Check for waste full and empty or drum waste roller and unblock the jammed toner inside that unit or check fuser gear if broken then replace it.
Nov 23, 2009 | Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Grayscale Copier Problem
Have you tried removing all cable connections on it and turning printer off and unplugging it from power supply and powercycle?
Apr 29, 2008 | Sharp AL 1631 Copier
Jams EVERY TIME
Where is the paper jamming? Out of the paper tray or under the drum or in the fixing unit? Did you make sure you have the paper tray set up to the correct paper size and orantation for the paper in the paper tray and dose it happen at any other time and where is it jamed up at. Need more info.
Mar 14, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
