Question about Sharp AL-1641CS Laser Digital Copier
Sharp AL-1642CS making blank copies
I have revised and clean the copier, took out toner and drum, they looks new but as you try to copy according to instructions, I had blank paper as result. Do you have any idea what could be wrong? I have double check original paper facing procedure with same result. What can be wrong.
I bought this machine like this.
Thanks
  • 1 more comment
  • Ledag Jul 18, 2008
    Thanks. I don't know what is a charged wire? I used the garage. it is really clean and I just did clean with moist paper and water. Then dried with towel paper. Thanks
  • Tim Babcock
    Tim Babcock May 11, 2010
    Open the side door and make sure you have a charged wire in there. Sometimes if the side door isn't closed all the way you can get blank pages. When you cleaned the machine, where did you do the cleaning at?
  • Anonymous Mar 20, 2014
    What would cause dirty/lacey copies on the Sharp AR-M355N? Would the photoconductive drum be the cause? The glass, etc. is clean and the original is good. I have pulled out the rod to the left of the toner and cleaned and put back in. Thank you very much.
  • Sharp Master
  • 2,794 Answers
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Posted on Jul 18, 2008
White "lines" on copies and prints ? - side to side every 1.5 inches ( approx) is blank ( no toner) creating "lines".
the drum is light sensitive and if one side was exposed to sunlight for as little as 20 seconds could have that effect , it is at best a shot in the dark (no pun intended)
Jul 13, 2013 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Prints and scans fine, but copies are all black
Hold down the auto expsoure key the the lights will began to blink light copies then push it again to hold lighter expsoure.
Jul 18, 2008 | Sharp AL-1642CS Copier
Toner Dumping in machine
Do you have a shop vac with a hose on it? Turn the copier OFF and UNPLUG it from the WALL and use the vac to do all the lose toner & use a brush to get into the cracks and hard to reach areas. The blotches are most likely coming from the paper path, make sure you clean the whole paper path and run some blanks pages in the copier to clear up any left over... Good Luck
Jun 04, 2008 | Sharp AL-1642CS Copier
Vertical lines on multiple page copying
Did you check to see if the lines are before or after the fixing unit? Stop a copy before it gets to the fixing unit. If there is no lines in the same spot, then the problem is in the fixing unit, if not check the and clean the optics and dust proof glass. Good Luck...
Apr 16, 2008 | Sharp AL-1642CS Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Sharp AL-1641CS Laser Digital Copier Logo
174 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
