Installed new motherboard, computer automaticly turns on, with out pressing power button and nothing comes on the screen
  • 1 more comment
  • Alex Keen Jul 17, 2008
    Hi There...
    Its a self build job...
    The motherboard model is: Asrock K8 Upgrade Vm800
    Being put into a Thermaltake Case
    And will be installing XP.
    I turn the power on from the rear and it starts auto, ive played around with the header leads, and nothing comes up on screen.
    i placed my old motherboard back into the computer and it works fine, i then swapped again and nothing happens
    Many thanks
    yea its new, nothing happens, got a AMD 64 septron chip
  • David Needham
    David Needham May 11, 2010
    Make/model motherboard?
    Make/model computer?
    Operating system?
  • 26 Answers
1. Check all connections again, especially the lead from the power button to the mobo. It seems a silly question, but is the four-pin ATX 12V connector firmly seated (it's gotta "click"). Yes, I know you've probably checked, but I had to ask. :-)
2. CPU fan connector--check/double check?
3. As fwadley so rightly noted, memory chip seating can be crucial as well (yes, another of my unpaid adverts for Crucial memory *heh*) Reseat. Use DeoxIt Gold or Stabilant 22 on essential electronic plugin components like memory, if you have ANY doubt as to connectivity/continuity issues. Try different memory modules.
IOW, it sounds very much like a missed/unfirm connection or grounding problem (yes, re-check positioning and connections of mobo to case).
Of course, recheck jumper settings (what CPU, exactly? Semprons come in various "flavors" and the jumpers can be set for either the 754 or 939 pinouts).
I recognize that you're not a beginner.These are just some of the things I'd recheck on an installation of my own gone south.
Oh, "nothing comes up on screen"--means "no video"?This board has onboard video, doesn't it? The BIOS should, IIRC, "automagically" bypass that for setup, at least, if you were to try a PCI card for testing. Grab an old PCI graphics card and give that a shot if suggestions above fail.
Please report back with any error messages or other information.
Posted on Jul 17, 2008
    Master:
    Sergeant:
  • 482 Answers
Take out memory chips and try it. is it a new one from a store?
I cannot access my Bios setup when pressing the Delete on start up
Try pressing the esc key if that doesn't work use the f12 key
Nov 11, 2012 | Intel Motherboard
I installed a new Flatron E2350 23" monitor but
see my friend some of the monitors are designed like this only look at the back side there is switch press it if not there look manuals don"t forget to give rating&vote to me for this answer
Dec 27, 2010 | LG Computers & Internet
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
No Display
hi....good day...>try to replace the ATX power supply...< thanks and good luck...^_^
May 29, 2009 | ASUS M2A-VM (0610839149438) Motherboard
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
I hook everything up and turn it on but i get nothing
if you just built a new pc, and hooked up your power button and reset button and mixed up the possitive and negitive wires you may have fried your motherboard. If you hold the power button for five seconds and your pc does not power down, it's fried.
Apr 11, 2009 | ASUS P5WD2-E PREMIUM GREEN INTEL 975X...
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Cannot get acer 3k series to boot at all, will not start up at all
Check the power supply - does the computer turn on and just sit at the boot screen with an error message? If the power light on the front is not on when you press the power button, your power supply might be faulty. Check the power cable to make sure it's connected properly.
Next, if the computer power light comes on but nothing displays on the screen, make sure that the video/monitor cable is connected properly. If nothing is displayed still, the CPU, memory, video card, or motherboard might be faulty. Most likely is your motherboard. You may be able to find a replacement one on the internet, or it might just be more cost effective to get a new computer.
Jun 10, 2008 | Acer Computers & Internet
Nothing happened when installed new computer - Please help
since the components are new,it must be other problem...I think that the problem is at the motherboard's jumpers...the power button, the restart button have wires that connect them with the motherboard so, u must not mess up the jumpers...i suggest u should download your motherboard manual and see exactly how the new components should be installed...
HERE, HOPE IT HELPS...
http://users.iafrica.com/g/gl/glynhall/hohweb/manuals.htm
Nov 26, 2007 | MSI K8D Master -FT For AMD Dual Opteron...
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
