Question about E-Machines T3065 PC Desktop
Motherboard Need a motherboard for a emachine t3065 what other boards will fit this case and cpu?
    Master:
    Sergeant:
  • 482 Answers
Call www.tigerdirect.com they can help you.
Posted on Jul 17, 2008
What does a pci port look like in a emachine pc
Those are the expansion bays to supprt a daughter board on the main mother board. They look differernt depending on the kind. Do a seach by image, because there are at least 4 variations.
Dec 24, 2012 | eMachines T5230 Motherboard Replacement...
How to replace motherboard
1. Contact eMachines, and purchase an identical replacement motherboard.
2. Disconnect all the exterior cables from your computer (keyboard, power, mouse, et cetera).
3. Remove the side-panels.
4. Disconnect all the interior cables from your motherboard (power, data, audio, et cetera).
5. Unscrew any screws holding add-in cards (modem, video) in-place.
6. Disconnect those add-in cards from the motherboard.
7. Unscrew the mounting-screws that hold the motherboard to the case.
8. Lift out the motherboard.
9. Take the RAM out of the old motherboard.
10. Take the heat-sink-CPU-fan and CPU off the old motherboard.
11. Put the CPU and RAM onto the new motherboard.
12. Reverse the above steps, to reassemble.
Jul 17, 2010 | E-Machines eMachines Desktop PC
I need a motherboard manual for CPU4266CEL Motherboard. It is in a emachines T3828
Hi
You can view/download the manual for your emachine from this link---
eMachine T3828 user/hardware Manual
Daniel Scott
Jun 28, 2010 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Fan Speed 100% on Intel D845GVSR motherboard
see if you plug them in the right spot cpu gose by the cpu case fan will say case on board some take two wire fans some 4 wire some 3 wire jim
Feb 20, 2010 | Intel D845GVSR Motherboard
To remove motherboard from laptop e-system ei3102
To remove the motherboard you need to remove power from the back, lay the computer on it's side, wear an anti-ESD wrist strap, remove the left side cover (looking from back of computer). Mark and record all connections (a video helps while you disassemble). Pull all connectors off by grabbing connector NOT wires. Some have locks. Remove all adapter cards (little circuit boards plugged in motherboard). Remove RAM by pushing on locks on each end. Remove the CPU fan and heat sink but PULL UPP CAREFULLY in case CPU stays attached. If cpu is still in socket, carefully lift locking lever and lift cpu straight up. Remove all screws. Board will need to slide forward slightly to get out of case. Take old board to store to make of proper replacement and take cpu also. Both should be in anti-static bags but DO NOT use ziplock bags. Install in reverse BUT cpu should fall into socket WITHOUT pushing, it has one corner of pins different from others. Make sure that you have wrist ******** at all times working inside the tower. Respond for further details if needed.
Feb 09, 2010 | E-Machines eMachines Refurbished EMA...
Will new micro atx boards fit inside of a hp 4550z case?
Yes i think you will be ok as i can see and your old motherboard is microatx but i strongly recommend you to change case because is not only about motherboard.You will need and better and new power supply and if you want to build a good system with air flow for not overheating your new cpu and other hardware i strongly recommend you to change and chassis!!You can find a "nice" case with $50-$70 bucks if you dont want to spend money on case,but you will need power supply for sure
Jan 07, 2010 | HP Computers & Internet
I need a motherboard that can use the same case and everything els as the p4vmm2 My case is the ATX with Intel celeron 2,4GHz
you can use any ATX mainboard into an ATX case, they are universal. Your cpu will only fit boards with the same cpu footprint so you need to know what socket your cpu is.. lga775 is most common now. I would advise a Gigabyte EP45-UD3LR board. Excellent board and well worth the outlay.. no issues with windows xp or vista and you can expand drives and ram as you wish..
Nov 02, 2009 | EliteGroup P4VMM2 Motherboard
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
Need to replace mother board
It looks like you have an AMD Sempron 3000 system. If you have a mid tower case, look for any atx motherboard that supports that cpu. If you have a mini case, you will have to look for a mini-atx motherboard. The description about the motherboard will give the dimensions of the motherboard and you can measure your case to make sure it fits before ordering. With it being such an old computer, I would not put a lot of money into the motherboard itself. check out www.geeks.com at http://www.geeks.com/details.asp?invtid=A8N-LA-PB-NP&cat=MBB for a good buy at about $35.00 USD.
Mar 29, 2009 | Computers & Internet
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
E-Machines T3065 PC Desktop Logo
135 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
