Question about MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/ DDR2/ A&V&GbE/ MATX Motherboard [7309-040(K9N6PG... (MB-K9N6PGM)
Installing xp freezes
Ok... i have a barebones kit... i had an asus motherboard however i thought it was defective returned for another but i am still having the same problem.. so here is my problem... windows xp freezes and can only boot into safe mode (not able to boot to safe mode w/networking either) each time i attempt to do a clean install i am able to load all the drivers except for 2 pci driver which i cannot find or recognize so i disabled it .. and still same issue... also during installation i press F6 to load my sata hard drive floppy either says the file is currupt or cant find it on my floppy,, i down loaded it to floppy and i do have the installation disk but safe mode wont let the cd auto install the drivers (since its in safe mode.) when all the drivers are installed i see that there are no errors they are all working properly.. but still freezes i tested different hds and they all have the same symptoms of freezing after install so i really hope it is not the processor.. i need help... what would the problem be???? i am able to access some files through cd rom in safe mode but can only go so far w/cd since safe mode wont let me run the full installation.. .. but i have no clue on what i need from the installation cd.
the OS is windows XP home edition
i have installed these hardware
motherboard - msi k9n6gm am2 socket (switched w/ASUS mobo same issue so mobo is tested ok )
amd athalon 64 X2 4400+
crucial ram DDR2 533MHz (i have 2 each were individually tested ok)
cd-rw
sata 80 GB ata hd ( i also attempted swap a different IDE hard drive had the same problem so the hd is tested ok )
  • 1 more comment
  • medicinedog Jul 18, 2008
    i did update all the drivers i could think of ... there is one driver conflicting with another (irq11 system managment pci -) unknown device .. im looking for the right hardware or driver.. ive been on the mobo manuafactures website,driver cd and even xp website (however i cant find anything that could help me figure out what the conflict could be) any clues?
  • medicinedog Jul 22, 2008
    ok..update,, i download pc wizard from another pc but i cannot install it into this pc since im in safe mode..im thinking maybe it doesnt detect the hardware since i dont have an updated service pack?? . i also thought of installing xp service pack 1 but i need to find the components for sp1 windows doesnt have a list or its jumbled with other service pack ( like 2 and 3) so i have no idea which ones i need. since its a clean install i dont know if i can install the service pack since i cannot activate windows because im in safe mode,, another option i have is downloading my cpu chipset but i need sp1 to do it.. i think the unknown device is REALTEK audio driver or media driver but i have no idea what file to upload as far as drivers go,, the manufacture cd only goes so far,but doesnt provide the driver unless i go thru setup which i cannot do in safe mode... its like im stuck between a rock and a hardplace
  • medicinedog Jul 23, 2008
    you i did a clean install again this time i loaded service pack 2 when it went into safe mode... and wouldnt you know .. that solved my issue,,, problem was that i have an early version of home xp... my issue is resolved thank you for your help,
  • 781 Answers
If it will only boot in safe mode it means you have a driver conflict.
This is only a suggestion but try fresh reinstalling windows, with only basic xp drivers then install other drivers one at a time rebooting each time you do until you come across the faulty one. remove it or check its for xp not vista research net for correct one
Posted on Jul 17, 2008
  • 1 more comment
  • David
    David Jul 18, 2008
    use a program called (pc Wizard) it will find all hardware and driver names even unknown device (it did on my computer) note name and number of device search and download
  • David
    David Jul 22, 2008
    On the internet there is a program called ERD Commander this boots from cd it enables you to check and change thing in windows and because its loaded from cd will boot up (try softarchive ) for it also there are cut down windows versions that boot from cd enabling you to access your windows installation try one of these
  • David
    David Jul 22, 2008
    On the internet there is a program called ERD Commander this boots from cd it should enable you to delete drivers from windows. you may be even able to use pc wizard.
    also there are cut down versions of windows available (softarchive) that boot from cd so you can access windows once again use PC wizard hope this helps
I just did not found asus p4p8x audio drivers
http://support.asus.com/download.aspx?SLanguage=en&m=P4P8X&os=17
Aug 01, 2013 | Intel Celeron D 2.4GHZ 533FSB Barebones...
I bought a barebones kit that has this motherboard. When I power it on, the system trys to turn on for about 5 seconds then the whole system shuts down. I called Asus support, they had me remove the cpu...
This could be a cmos battery or you need a bios update.
You will possibly need to call the manufacturer or go to the site and see if there is a bios update.
The cmos battery possibly needs to be replaced if this doesn't work then you will need to get a new board. This board is defective and if this is your second board then go to another manufacturer.
Oct 05, 2010 | ASUS M2N68-AM SE2 Motherboard
Video of, How to assemble a Asus desktop.
Why Asus?
It's going to be an Asus motherboard. The rest of the parts will not be Asus.
If you bought a desktop computer that is a barebones unit, the number after the Asus name, is the motherboard Model Number.
Example:
Asus M4A785-M Ultra Barebone Kit.
The motherboard is an Asus M4A785-M
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6046490&CatId=31
Asus didn't make the computer, just the motherboard.
Information you need is how to assemble any desktop computer, and transfer this information to your computer build.
1) http://www.youtube.com/watch?v=LIaNP2eWWuI&feature=related
Also click on the other related videos to the right, under Suggestions.
2) http://www.squidoo.com/how-to-assemble-a-computer
Scroll down to the heading -
Table of Contents - How to Assemble a Computer,
and click on the links in order.
Now, tell me what Model Number of Asus motherboard you have, or what Asus barebones kit.
I'll guide you step by step.
1) Right off the bat!
Suggest you buy, and wear an ESD wrist strap.
(Electro Static Discharge)
Average cost is about $6 to $8.
Connect the alligator clip of the ESD wrist strap, to the metal frame of the open computer case.
You don't want to Static shock any of your computer parts!
A Processor is the most susceptible computer hardware part, to Static shock.
[Static will fry out (Short Circuit) the hardware components of a computer. You may not even see it, or feel it ]
2) Work on a table.
Do Not remove any parts from their protective Anti-Static bags, until you are wearing the ESD wrist strap, and it is connected to the metal frame of the open computer case.
3) IMPERATIVE!
Make SURE you have Thermal Paste.
Thermal paste is put in-between the top of the Processor's case, and the bottom of the Heatsink.
Helps to transfer heat from the Processor to the Heatsink.
There is a Correct method, and an in-correct method of applying thermal paste.
(Thermal paste is also known as thermal grease)
4) Make sure the parts you have are compatible with each other.
If you bought a barebones kit, the parts that come with it are compatible.
If there are parts you still need to buy to complete this computer system, they have to be compatible with the parts that have been already provided.
Post your reply/s in a Comment.
Sep 28, 2010 | Computers & Internet
Is there a sound driver for windows xp pro as the downloaded driver from asus main website only says xp and wont work Asus Terminator Barebones A7vT Sound max
Usually, you get the drivers for XP, Vista, etc. The XP version should be fine enough for you. If you are not able to get your audio even after installing the driver, then the issue could be something else. If you are able to see the speaker ICON on your task-bar, then this means that the sound is enabled.
Mar 19, 2010 | ASUS Terminator A7VT Barebone
Windows 7 freeze after few minutes... please help vista freeze after few minutes
Could be a hardware related issue. I would check for bulging or leaking capacitors on the Motherboard.
If all capacitors seem to have flat tops (the "X" is not raised or leaking), Then I would try new RAM - Memory Modules as they can cause freezing if defective. Download and install MemTest to see if you have any defective modules http://www.memtest86.com/download.html.
If RAM is OK, then you could have a defective hard Drive. Try testing a different Hard Drive or run SpinRite http://www.grc.com/sr/spinrite.htm to test and repair your Drive.
Jan 15, 2010 | ASUS P5VDC-X Motherboard
ASUS M3N78-VM motherboard Problemes
Good Motherboard...BTW... Reset BIOS to Factory defaults. Make sure you have the latest BIOS as well. Then you need to eliminate the other devices. Try running just on the On-Board Video...see if crashes. Run w 2 Gig Ram...same same... and of course the processor which may be impossible. Once you know it is MB or CPU... you make a choice which to buy or test. MB first... you can always return with less stress.
Dec 31, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Asus A7V600_X Motherboard
do you have a jumper on it set to master? Do you have the right cord? Is it pluged in right?
Oct 01, 2009 | ASUS A7V600-X Barebone Kit / ATX Mid-Tower...
I havent the sound
install this program
http://www.cpuid.com/download/cpuz_150.zip
it will give you your motherboard version
once you have that version number, go to your motherboard manufacturer's site and download the software for your motherboard.
install that software, restart your computer and you should be all set.
helpful , fixya
Mar 23, 2009 | VisionMan Asus Crosshair Socket AM2...
Board driver
Here is a great place to start. Enter your product, series then model and it should point you in the right direction. Here is the link.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 12, 2008 | ASUS D1 500 (ap d1500) Barebone
Asus T2-P
Try re installing the usb2 drivers from the motherboard drivers. Although they will not show up as as usb 2 in the device properties, use sisoft sandra (free download), as this will show them as high speed or usb2.
Jan 28, 2007 | ASUS (t2psimpledlx) Barebone
MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/ DDR2/ A&V&GbE/ MATX Motherboard [7309-040(K9N6PG... (MB-K9N6PGM) Logo
273 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
