Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore Elite Model 795 77244601
2 months past warranty!! heard a louder than usual noise, now the front panel reads ER FF. Fridge seems to stil cooling, removed frozen foods just in case. Can't get a tech out from Sears till late next week, Family of 7 need help !!! Thanks.
  • 2 more comments
  • bucky6 Jul 28, 2008
    Sorry to hear your dilemma. Have the same thing going on. I purchased mine 14 months ago. Cleaned under and behind panel. Unplugged a few times. Finally have the display panel showing normal. Kenmore/sears was no help. Called on monday and said their tech could get here by friday.
  • Anonymous Aug 01, 2008
    AgAldana
    Have the same problem with digital display locking up and reading error. The temp seems to be steady. Unplugging seem to help it but the problem recurred again the next morining. Just had this installed yesterday and I'm afraid this might be a recurring thing down the road, especially when warranty has elapsed.
  • Anonymous Aug 13, 2008
    The readings on the display would take turns coming on. The temp would count down from 40 or so to 30 and various blinking would occur. Refridge and freezer were losing temp. Called sears help and they are coming out this Monday. I will follow up with their response.
  • thetal Oct 07, 2008
    Yes I have the same if not similar problem I get a 22 or 88 error on the display. Seems to still work but it beeps for a while and then seems to correct itslef. Calling Sears tomorrow, warranty up next month
  • 15,935 Answers
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Er FF ON THE BORD
FF usually means the freezer fan is not working. If the fridge is cooling poorly, check to see if the fan inside is running while the compressor is running. If not, and if there's no ice jamming it, then you need a new evaporator fan. If the fridge is cooling normally and the only symptom is the error code, then it could be a problem in the electronic control.
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not working
Error code ER FF and evaporator fan makes loud noise
Aug 15, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
335 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
