1993 Honda Prelude Logo
Anonymous Posted on Jan 24, 2011
What kind and how much oil do i need to put into my 1993 honda prelude?
Jeremy W.
Level 3:
Top Expert:
  • Honda Master 5,332 Answers
  • Posted on Jan 24, 2011
Jeremy W.
Honda Master
Level 3:
Top Expert:
Answers
5332
Questions
0
Helped
2060218
Points
17799
Usually between 4 and 41/2 quarts after you drain the old oil out of the pan and put on a new filter.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
  • Jeremy W.
    Jeremy W. Jan 24, 2011
    I should add that the oil level on the dipstick should be at the full mark when you are done adding oil. If its below you need to add more. If its above you added to much.
Randy Ohler
Level 3:
  • Honda Master 14,585 Answers
Randy Ohler
Honda Master
Level 3:
Answers
14585
Questions
8
Helped
3946853
Points
39683
Any kind you want, just stay 40 wieght or lower. It takes about 4 and 1/2 quarts
1 Related Answer
A Miller
  • 8404 Answers
  • Posted on Apr 12, 2010
SOURCE: what kind of transmission oil do i put in my honda
Go to the auto parts store and tell them you want a quart of transoil for your Honda, they will direct you ...
1993 Honda Prelude- Oil Pan gasket keeps getting pushed out, then leaks. PCV checks OK-
trying putting silicone on first and tighten down in a crisscross pattern first hand tighten all the bolts then finish tightening the rest of the way
I need to know where to put the hydraulic fluid for my shifting in a 1993 honda prelude 2.2 dohc vtec
I THINK you mean fluid for the Clutch? its a little resrvoir near the brake fluid reservoir at the firewall, just to the left of the brake.
What kind of transmission oil do i put in my honda prelude 2.0 si 1987
How do you replace a 1998 Honda Prelude SH fuel pump
If I remember correctly, on the prelude it can be reached through the trunk. Lift the carpeting and/or mat to expose the access door.panel. Disconnect the negative side of the battery for safety purposes. Label the fuel lines with a piece of tape if you like. Disconnect them. Remove the nuts that hold the assembly in. It's usually best to put a mark on the pump and the tank, just in case you have any trouble aligning the new one in the tank. Carefully remove the pump assembly with a lifting and turning motion remembering what angle the pump faced. It's relatively quick and easy.
Kindly get back to me with a kind word if I've helped in any way.
1helpful
Honda prelude 93 auto transmission: "s" light flashes
Try changing the Transmission oil - can solve a host of problems, including rough changes.
1993 honda prelude si 2.3 liters cuts off while driving
Smoking out the tailpipe is usually caused by worn rings, or really worn valve guide seals. (if it is an oil smoke) If it is a black smoke, it is running too rich, maybe an injector leaking or stuck open.
No oil pressure in my 1993 Honda Prelude 2.3 DOHC H23A1
my car did the same thing the problem was a $14 washer inside the oil filter fitting on the car you have to pull the filter conection off (from the car) bit of an *** around but pretty simple.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
