Question about InFocus LP70+ Multimedia Projector
Infocus LP70 dropped and now the focus is jammed.
  • NicoNell Jul 28, 2008
    I have dropped my in-focus and need somebody do repair te focus problem
  • 2,237 Answers
Try pulling the outer ring out a little while twisting it (you won't break it). then try the inner ring. if it wiggles, you need to take it apart- and that's not a pretty job.
Posted on Jun 05, 2009
    Scholar:
  • 167 Answers
Hello, The impact has caused damaged to the lens focus cam/pins and will probably need to be replaced.
If you would like more information regarding this you can contact me, dennis@sagertronics.com
Take Care!
Posted on Dec 29, 2009
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
Jammed projector lens infocus lp770
get a wide bladed flathead and find the widest part of the **** between the focus ring and zoom. work the blade like you are trying to widen the the slot, do this all the way around till it pops back into place.
May 31, 2010 | InFocus LP70+ Multimedia Projector
InFocus LP70 keeps shutting off
if the fans go off imediately too, it's the power supply. if the fans stay on, it's either the lamop, ballast, or colorwheel. either way, you may need to send it in to an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 14, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
Does anyone know of a repair/service center in NYC for an In Focus LP70 Projector?
there's one in rochester, ny. av solutions. i believe they are an authorized infocus service center. www.avsolutionsny.com
Jun 29, 2009 | InFocus LP70+ Multimedia Projector
Dropped LP70+, now can only focus about half the display
the focus lens is jammed. if it is hard to spin, force it a little and it should snap back into place.
Dec 24, 2008 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
Lp70 projector Error message about Fans
I had a similar problem with an LP70. my fan was sticking.
So I opened bottom cover and pulled out fan cage, there are 2 fans.
you must know which fan not running.
If you found bad one remove paper label(yellow)
you can see 3 small holes.
using wd40 few drops to holes.
then manually turn using your finger cw and ccw few times
you can feel smooth turning now.
then relabeling to hole side.
reassemble unit.
power on.
Now you can enjoy with your projector.
Jul 18, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
359 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
