Question about NaturalPoint TrackIR 4 Pro - Headtracking system
Flight Sim X problems with TrackIR 4 Pro
I have a TrackIR 4 Pro which is properly installed and does track. I have configured the FSX profile for "Flight" and when I load FSX and get into a virtual cockpit....zip, nada, nothing. I know the TrackIR is tracking and working properly as I can see evidence of that within the tracking window of the TrackIR software. What does it take to get this device working with FSX...pre-service pack 1 or 2? It would be helpful if you could send any suggestions to my email address too. roberth@humboldt1.com Thanks much for your time and effort.
  • 1 more comment
  • birkerod Aug 29, 2008
    The same exactly
  • Anonymous Sep 03, 2008
    Birkerod does not have the same problem any more. Installing SP 1+2 solved th problem
  • weejock77 Oct 19, 2008
    when i try to take of from runway the plane stalls then starts and stalls for about 2mins then take of perfect and flies perfect but when it lands it stalls again for about 1 min then is ok ??? millarwj@tpg.com.au
For me service pack 1+2 solved the problem
Posted on Sep 03, 2008
All views move to different positions when connecting the yoke, cannot pan up or down only left or right when the FSX Options-Settings-Controls-Enable contollers is not ticked. When I "enable" Contollers I...
Hello
In the control options of fsx you need to delete the default keybind for the view you want assigend to your joystick.Then replace it with your controler axis.Or you can use the software and do your own program for fsx.The views in fsx have always been an issue or a problem with the game.
Also panning down in fsx and reverting back up has always been an issue or a clitch in the simulator.it does however work in fs version 9.
Using Fsuipc with a weather program or a virtual airline should not make a difference in control settings.
Jun 06, 2011 | Saitek Pro Flight Yoke System Flight...
Computer crashed now formatted with vista home and trying to reinstall flight sim X but it keeps coming with this message microsoft flight simulator x scenery world texture 024C2 Sul.BMP
FAT32. The File System used by Win98SE that has no security like NTFS file/user permissions. The lack of FAT32 security may be your answer to a lot of problems with FSX. Mine was a license issue + couldn't install ACCELERATOR pack. Windows 7 offers all the tools to create a FAT32 from available space from your C drive. ControlPanel>>AdminTools>>ComputerManagement>>Storage>>DiskManagement. Right Click on Drive C and click "shrink volume". Set shrink size to just under 32 GIGABYTES. Then format it as FAT32, Reinstall FSX into the FAT32 partition and ENJOY!!!. The install may take almost 2 hours so just let it sit. This (installing into) FAT32 thing will solve so many issues. In NTFS, if security on one file it tries to access - fails or a service FSX needs to run fails THE APP WILL FAIL!!!!
Oct 10, 2010 | Microsoft Flight Simulator X
Is MaxfFighter F-16 U good to play with in FSX?
If this is a USB device and the driver has been installed, chances are it will work.
If you go to the Setup in the Flight SIM program and can select/configure the joystick, then it will definitely work.
Oct 09, 2010 | Genius MaxFighter F-16U. USB PC Joystick...
When i installed REX for fsx, my pro flight multi panel sis not work anymore...what do i do???
Reload the driver disk and in the directory that it installs into there is an icon which forces the switch panel to start up. You only need to use this option once then it will continue to operate normally.
Jul 07, 2010 | Saitek Pro Flight Multi Panel (PC) Flight...
Bought the saitek headset how do configure to talk to the tower in the fsx game
You cannot talk to the tower in FSX, only via third part software and then the button you wish to use would be configured within that software (such as Live ATC),
May 15, 2010 | Saitek Pro Flight Yoke System Flight...
Unable to find fsx in windows registery unable to complete flight deck5 setup
Have you searched the registry using CTRL + F and typing in FSX or Microsoft? This should find all entries. If not, then FSX is not installed properly and you need to uninstall FSX, reboot and re-install. Good luck with it.
Jan 31, 2010 | Abacus Flight Deck 5 Expansion Pack for...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Flight Sim X fails to load at statup
Check your video card and its drivers are up to date and not corrupted. Might be worth downloading new drivers. Basically after the menu screen the sim enters Direct3D mode and if there is a video driver problem, this is where it will pop up and start causing problems.
Jan 20, 2009 | Microsoft Flight Simulator X for Windows
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
NaturalPoint TrackIR 4 Pro - Headtracking system Logo
831 people viewed this question
Top NaturalPoint Video Game Consoles & Games Experts
James Wishart
Are you a NaturalPoint Video Game Console and Game Expert? Answer questions, earn points and help others
