Whirlpool/Kenmore Calypso Washing Machine FL code - (Overfill problem, and yes, there is water laying in the washing machine. This problem was caused by washing an old bath rug. Bits of the rubber backing came away in tiny pieces. I believe a bit of the rubber got jammed in the pump housing and seized the pump impeller. How do I take this machine apart, locate the pump impeller in order to clean it out?
    Genius:
  • 1,028 Answers
Not overfill since no water overtop just switch detecting too much water...lean washer back remove 3 screws holding bottom panel on newer pumps have torx screws in bottom id any way possible remove a much water as possible first may try leaning washer foward after removing bottom panel remove the screws in bottom of pump and clean..older pumps were harder to clean and replacement was easier but more expensive..new style comes with motor attached
Posted on Jul 17, 2008
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washing machine stops
FL = Overfill
You should check your pump. If the pump is letting the washer overfill, replace it. Look around for some ways to take the cabinet off.
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Calypso wash motion washing machine FL code stuck
Calypso washers have been known to be problematic. In fact, there is a class action suit out there which could be beneficial to you: http://www.calypsosettlement.com/ According to Whirlpool FL stands for Flood Condition. Here is their explanation of it: ----- FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. ----- Hope this helps.
Aug 07, 2006 | Whirlpool Calypso GVM9959K Top Load Washer
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
