Question about HP Pavilion dv6000z Notebook
Heatting up i bought a hp pavilon on sat everytime i use it it heats up. the battery and the wire.
    Master:
  • 788 Answers
There is probably a short in the AC adapter wire. You could test it with a multimeter to see if the voltage fluctuates when you wiggle the wire.
Also try running to notebook without the battery to rule out a bad battery.
Some amount of heat is normal though.
Posted on Jul 17, 2008
I bought a fan motor for my hp 2100, when i went to swap it i found the new fan had 1 less hot wire than the old 1. when i installed it, it does not work. could i have bought a 110 motor when i need a 220?
old motor has data needed for replacement. hp, sf ,rotation ,rpm, volts and amps.plus capacitor size required. the extra wire can be for a capacitor conection usaly brown in color and if you look at the label it will tell you how to eliminate the need for this wire.
Aug 21, 2013 | Hayward Heat - Pro 2100 Heat Pump Pool...
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
Cd/dvd drivers
i think i ur country's hp website(manufacturer) u can get all drivers just search there and download
Feb 26, 2010 | Battery Technology (HP-DV1000) for HP...
I have a problem with my cd/dvd drivers and my
just go to maufacturer website u get ur driver there
I have a hp pavilon dv2000 and the fan is very loud when i turn it on, after like 30 min or 40 min when the laptop start heating up, the fan works but it not loud any more? any help at all with this...
do this I fix 4 to 5 a day.... in the back of the laptop you see a air vent - you must blow air in reverse order thru the fan vent grill to make sure it isnt clogged .... im my show i have a automotive air tank and it does a great job - 75% of all laptops i service have stopped up GRILLS see video about 2:18 in this video yopu will see how hair and dust has clogged this grill and the computer is turning itself off :()
http://www.youtube.com/watch?v=ZS2tKwhigyE
Dec 29, 2009 | HP Pavilion dv2000t Notebook
What makes heat change over to aux heat?
depending on how your installer wired it
when you turn the unit on, it could use both to get to temp as quickly as possible
when you are out of balance, the outside temp is lower than 20 degrees, not alowing any heat to be captured by the heat pump
or when your compressor goes inot lockout, but thats a rare wire situation
finally again depending on wire install and t sat as a user option
Oct 17, 2009 | Goodman CLJ30AR32 Air Conditioner
My HP Pavilon Zed 145 wont start up. Keep turning
Try to run on AC power with battery removed. If still problem persists, then its time for repairs!!
Sep 06, 2009 | HP Computers & Internet
The screen go blank on my hp pavilon dv 2000. Why?
If you've checked the battery and power cables are connected properly then you've done as much as you can do, you'll need to take the laptop to a HP repair centre.
May 17, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How Do I Dismantle?
Just read this manual and do :
h10032.www1.hp.com/ctg/Manual/c00444840.pdf
May 16, 2009 | Battery Technology (HP-DV1000) for HP...
Emergency heat comes on everytime heat pump starts UPKA025JAS
Your white wire is controlling the heat for your strips. while the blue is for the heat pump side of heat. But if you disconnect the white be sure to wrap tape around it so it doesn't contact any other wire. Would cause a short and you would loose a transformer.
Jan 25, 2009 | Heating & Cooling
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
