Question about Panasonic Microwave Ovens
I have just bought a NN-CS596S. I followed the unpack and startup instuctions without amy problem. It will now work consistently on microwave thogh. It works fine on grill or oven, but seems to have an issue with the door (or maybe just a loose connection somewhere) If you slam the door shut, it will let you start microwaving, however, if you just lightly touch the door handle it will stop(and forget its cooking settings). What shall I do?
  • fizzie Jul 18, 2008
    vendor has agreed to arrange a return / swap thanks lizzie
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
It may have been damaged in transit. A loose door may leak microwave energy.
I'd return it to the dealer since it's so new and under warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
  • William Miller
    William Miller Jul 19, 2008
    Sounds like a Fixya! to me.
My Panasonic NN-CS596S cuts out after nearly 40 secs on the microwave program, and then displays the H98 code. My contract with the Gas Board provides a call- out engineer, he has changed the Magnatron,...
It should be worth having it looked at. The magnetron is the most expensive part to replace, since it is new I would have it looked at it might just be a door or interlock switch(cheap fix). Here is a link for DIY's http://appliancehelponline.com/microwavetroublshootingvideo.html there are also videos on testing each component at http://appliancehelponline.com/microwave.html
Oct 07, 2010 | Microwave Ovens
My Panason NN-C994S is on demo mode and I am unable to switch it back? Do you have instructions to convert back to cooking mode. Thank you
If you go to the Panasonic site you can download the manual.
www2.panasonic.com/consumer-electronics/.../model.NN-C994S
Regards
Alan Hood
ami-man
UK
Apr 05, 2010 | Panasonic NN-C994S Convection/Microwave...
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
Microwave NN V622m locked
The owner's manual for the NNV623 is here, and it says to turn the Child Lock off, press the Stop/Cancel pad three times.
To turn on the Child Lock, press Start three times.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Operators manual for NN-ST656W Panasonic
Your search is complicated by the fact that this is an Australian model.
Your manual and other documents related to this model can be downloaded from this page.
Aug 02, 2008 | Panasonic NN-T888S Convection/Microwave...
We have recently purchased a Panasonic Convection Microwave (Model No: NN-CS596S) and have had to return one unit to the place of purchase due to being close to catching fire - thick black smoke inside and...
I would consult your owner's manual. If you don't have yours, you can download one here.
Aug 02, 2008 | Panasonic Microwave Ovens
To lock, press START 3 times. To unlock, press STOP/RESET 3 times. If this doesn't work, contact Panasonic Support at http://www.panasonic.com/support/
Mar 26, 2007 | Panasonic NN-V671S Convection Microwave...
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
