2001 Hyundai Elantra Logo
A
Anonymous Posted on Jan 24, 2011
I have this eobd code problem p0105 in my elantra, where those sensors?
ZJ Limited
Level 3:
  • Hyundai Master 17,989 Answers
  • Posted on Jan 24, 2011
ZJ Limited
Hyundai Master
Level 3:
Answers
17989
Questions
0
Helped
14449555
Points
60858
P0105 - Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
The MAP (Manifold Absolute Pressure) sensor is part of the fuel management system. It reacts to changes in engine manifold pressure. The PCM (Powertrain Control Module) monitors the MAP sensor continually to properly run the engine. Changes in engine load require changes in the amount of fuel injected, and timing of the ignition system, etc. An engine under load has more manifold pressure(or less vacuum) than an engine that is coasting. As the load changes, the MAP sensor voltage signal to the PCM changes accordingly. To check the MAP sensor operation, though, the PCM watches other sensors to verify that the MAP sensor is working properly.
For example, the PCM compares the TPS (Throttle Position Sensor) signal to the MAP signal to verify the MAP signal isn't "sticking". If the PCM doesn't see a MAP sensor change immediately follow a change in the throttle pedal sensor, it knows there is a problem with the MAP sensor and sets P0105. Or, if the PCM notices that the TPS indicates the engine is under load, but the MAP signal indicates that the engine is "coasting" it, again, knows there is a problem with the MAP sensor or TPS and sets P0105.
Symptoms of a P0105 check engine light code may include:
* Poor running engine
* Engine runs rich
* Engine won't idle
* Engine backfires through tailpipe
* Engine misfire under load or at idle
* MIL (Malfunction Indicator Lamp) illumination
* In some extreme cases there may be no symptoms other than MIL illumination
Causes: A P0105 DTC could be caused by:
* MAP sensor vacuum hose disconnected or plugged
* Bad MAP sensor
* Bad TPS
* Damaged or problematic MAP sensor connector
* Damaged or problematic TPS connector
* Damaged wiring
* Short to reference voltage on signal circuit of MAP sensor
* Loss of ground to MAP sensor or TPS
* Open on signal circuit of MAP sensor
* Bad PCM
Possible Solutions:
Using a scanner or code reader, turn the ignition on and engine OFF; what does the MAP sensor voltage read? It should be about 4 Volts for sea level. If you are at a higher altitude, it should decrease about half a volt or so for each 1,000 ft. of altitude (this will vary from model to model) Or if you have a separate MAF (Mass air flow) sensor on your vehicle, they are usually equipped with a Barometric pressure reading. If so, the Baro reading should match the MAP reading (they both measure ambient air pressure). If they're roughly equal, then, check for Freeze Frame data of the MAP sensor (if available).
NOTE: Freeze Frame data is the PCM recording a fault when it happens. It captures the readings of the various PIDS (parameter identifiers)available to troubleshoot what happened. It's like a recording of the problem as it happened. At idle a typical MAP sensor Voltage reading should be about a volt, and at WOT (wide open throttle) it should approach 4.5 to 5 Volts. As for the TPS, at idle, the voltage reading is about 1 Volt or less. As the throttle is opened the reading will increase to 4.5 Volts at WOT. Do the two readings make sense? For example, if the TPS reading on Freeze Frame data shows 2.5 Volts (indicating partial throttle) does the MAP sensor indicate a reading that isn't at either extreme? Using the Freeze Frame data (if available) compare the MAP reading to the TPS when the problem occurred. This can help you identify what happened
If you have no access to Freeze Frame data then check if the MAP sensor voltage changes when you apply vacuum to it. You can do this by mouth or a vacuum pump. The voltage should increase as you apply vacuum. If the reading doesn't change as you apply vacuum, make sure there are no obstructions in the hose to the sensor. If the hose is clear, the MAP sensor is usually bad, but it doesn't rule out the following from causing the problem: Does the MAP sensor appear to be stuck at less than .5 Volts? Then:
NOTE: This code shouldn't set if the MAP is stuck at extremely low voltage, however, I'm adding it in because there's no way to know for certain for which vehicles a low voltage condition may set a P0105.
1. Inspect the wiring harness and MAP sensor connector. Repair any damage
2. Unplug the MAP sensor connector. Also, at the PCM connector, remove the MAP sensor signal wire and check for continuity to the MAP sensor connector. If there is infinite resistance, then repair open in MAP signal circuit. If the signal wire has continuity to the MAP sensor connector, then check for 5 volt reference voltage to the connector and a good ground. If both are present, then re-install all removed wiring and replace the MAP sensor.
Does the MAP sensor appear to be stuck at full 4.5 voltage? Then:
1. Inspect the wiring harness for damage. Repair as needed
2. Remove the MAP sensor signal wire from the PCM connector. With a voltmeter measure the voltage with KEY ON ENGINE OFF. Is there 4.5 Volts? If so, unplug the MAP sensor and recheck. If it is still present, then repair short between the signal wire and 5 volt reference wire.
3. If unplugging the MAP sensor causes the voltage to disappear, check that the ground is intact. If it is, then replace the MAP sensor due to internal short.
MAP sensor codes include P0106, P0107, P0108 and P0109 .
LOCATIONS:
Manifold Absolute Pressure (MAP) Sensor: The MAP sensor is located against the firewall to the left side of the engine.
Barometric Pressure Sensor: This sensor is installed on the VAF sensor; Volume Air Flow Sensor Is located in the air intake plenum assembly.
Hope this helps.
1helpful
Code u1000 code p0105 u1152
Codes U1000 & U1152 are related to the digital data bus communications, U1152 is specific for the HVAC control unit data bus. troubleshooting this will require a Tech II scan tool.
P0105 is related to the MAP sensor circuit.
Code P0105
The code P0105 relates to the MAP sensor, why are you changing coils?
NO POWER TO SPARK PLUG toyota noah 2003 showing error code p0105, p0110, p0115. some one help me plz.
code p0105 refers to manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor--circuit malfunction===causes --wiring---MAP sensor--BARO sensor--ECM
code p0110 refers to intake air temperature (IAT) sensor--circuit malfunction===causes---wiring ---IAT sensor--ECM
code po115 refers to engine coolant temperature (ECT) sensor--circuit malfunction===causes---wiring--ECT sensor---ECM
1helpful
My 2001 Hyundai Elantra is dying alot the engine light codes are p0720, p0105, p0445
code P105 is manifold absolute pressure barometric pressure circuit. code P0445 evaporative emission system purge control valve circuit shorted. code PO720 AT output speed sensor circuit open or short ground.HAVE MANY CODES COULD BE ECM FAILING HAVE DEALERSHIP CHECK OUT ECM.ECM COULD HAVE SHORT OUT PC BOARD.
1helpful
I went to scan my toyota yaris car and the following codes were give ; temperature ckt low input po117
EOBD II Error Code: P0117
Fault Location:
Engine Coolant Temperature (ECT) Sensor (G62) - Low Input
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
Coolant thermostat.
Wiring short to earth.
Engine coolant temperature (ECT) sensor.
EOBD II Error Code: P0340
Fault Location:
Camshaft Position (CMP) Sensor A (G40), Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
Wiring from/to Camshaft Position Sensor (CMP) faulty.
Camshaft position (CMP) sensor faulty.
Timing misaligned.
Possible Solutions:
Check Wiring from/to Camshaft Position Sensor.
Check Camshaft Position Sensor.
Check Timing.
EOBD II Error Code: P0500
Fault Location:
Vehicle Speed Sensor (VSS) - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Non Emission Fault - No warning light.
Wiring.
Vehicle speed sensor (VSS).
Engine control module (ECM).
I need to know the drive cycle for my 2001 elantra .I had code PO105 that is fixed but it wont reset
P0105 = Manifold Absolute Pressure Sensor Circuit Malfunction
I assume the code will not clear when you try to erase it? Either the circuit (wiring) is damaged, or the ECU memory won't reset/erase the code. If you know the wiring & MAP sensor are ok, try zero-ing the electrical system (disconnect the negative battery cable and connect a wire to the negative battery cable & connect the other end of the wire to the positive battery cable for 30 seconds. Remove the wire & reconnect the negative battery cable to the negative battery post. Now, this shoud have erased the memory in the ECU and there should be no code(s) present. If the code is still there, (and there's nothing wrong with the wiring between the MAP sensor & the ECU), the ECU is faulty.
1helpful
3answers
Check Engine light came on, had it diagkimbelaustin@gmainosed, code P0105 What problems are under this code?
A P0105 DTC could be caused by the hose to the sensor being disconnected or leaking, the sensor itself is bad, or a wiring problem at the harness. The Throttle Position Sensor (TPS) should be checked as well as sometimes a problem here causes MAP sensor problems (bad ground, wiring). In extreme cases, the PCM is the problem (Power control Module).
1helpful
P105
it is located on the intake manifold,tocheck turn key on,probe volt.on1st and4th wire of sensor plug normal reading is4 to 5volts if ok,start car let run till norm. temp.probe wires again while car is idling,norm.reading is0.4 to 2volts,if any of these is out of range change sensor
1helpful
Volvo S40 Error code P0110 and P0105
there is two sensors that those code refer too. The map sensor, and the iat sensor. and both would have an effect on gas mileage. Both sensors would just make the car run a rich mixture.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
