I require the current replacement hard drive for a Dell 2200 Laptop. The defective HDD is a Hitachi TravelStar 40GB P/N HTS548040M9AT00 ATA/IDE. My Computer. Thanks Parry
Latoof has supported my own thoughts. Identifying and being confident with the chosen item was the next concern. Why did I worry??
All good, thankyou!
Posted on Jul 20, 2008
  • 287 Answers
Any ATA/IDE 2.5in HDD should fit your system.
for example THIS
Posted on Jul 18, 2008
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
Al querer instalar wxp-sp2 me aparece el mensaje que no encuentra ningún HDD, pienso que es porque no reconoce los drivers. La máquina es una Laptop Dell Latitude c840 y el HDD es un...
Creo que ese laptop no supporta SATA para XP, y se puede tratar hacer lo con un cambio en BIOS.
Prende el laptop, y empuja "F2" inmediatamente cuando aparece el Dell logo. En el setup menu en BIOS empuja "SATA native mode" para tenerlo apagado.
Inserta el Windows XP CD en el CD ROM drive, y apagar y apagar el lapto.
Jan 14, 2018 | Hitachi TravelStar DK23EB Series DK23EB-40...
HDD is cactus, what are replacement alternatives for the OEM?
You can use any 2.5 inch ATA/IDE drive as a replacement. Notebook hdd's are a smaller size than regular desktop hdd's. You can find a good idea online at stores like or Hope this helps & please rate this answer fixya. Thanks.
Feb 03, 2009 | Hitachi hts548080m9at00 80 GB Hard Drive
please suggest us the solutions of locked 40GB above said hard disk and how to unlock it?
Dec 14, 2008 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Dell laptop with no cdrom and travelstar HDD
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Jun 26, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Hitachi DK23EB-40 HDD
Basically what you have posted covers all that you need to know and do. The only issue would be the capacity in Gb of the new HD. Most currently available are far too big for your laptop. What you need to get is any 2.5" HD that is identical in size or just slightly bigger than what you used to have. Three reasons for this: 1) your motherboard may not recognize the newer/bigger HDs and therefore you would probably encounter problems even at the BIOS/CMOS stage; 2) the power requirement of the newer HDs may not be compatible with what your laptop can supply; and 3) the heat generated by newer HDs is considerably higher but your laptop was designed to accommodate older models only.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Hitachi TravelStar DK23EB Series DK23EB-40...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
