Question about Haier Heating & Cooling
I have an air conditioner (not sure of the exact model.). There is a Reset and Test button on the plug, and when I plug it in the reset button pops up causing the air conditioner to not turn on. I attempt to press it again, but it only pops back up.
  • 1,420 Answers
The compressor is stuck. Call a technician, sorry.
Posted on Jul 17, 2008
The reset button keeps popping when I plug in the unit? It won't turn on
when the reset button pops it indicates an over load situation and it works to prevent further damage to the unit
could be a start run capacitor failed or the compressor seized
call an ac technician for a check and a quote
May 28, 2016 | ACE Artic King Window Mount Air...
My reset button on the cord pops when I try to reset it. is it the cord that's bad? if so can you by pass it somehow
Air conditioner's reset button keeps popping out? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 28, 2008 - The breaker went bad recently, and had been replaced. The AC worked great for 2-3 days after. ... Then the reset button in the cords started popping out. ...If this is a window ac with the reset button on the plug, could be that the ... I'd try (after turning off the circuit and verifying, of course) opening up the ...
Quick Fixes for TV Picture Problems - Cox Communications
www.cox.com/residential/support/.../article.cox?...
Cox CommunicationsOct 20, 2015 - Learn quick troubleshooting steps for your TV picture problem. ... TV picture problems often have a simple cause and solution that you can easily ...troubleshooting steps, try our Cable Reset Tool by clicking the button below.
Wall socket buttons: What do the "test" and "reset" outlet ...
Dec 15, 2015 | Heating & Cooling
Why does it starts up then shuts off and all the lights start blinking
Hey friend, I appreciate your post!
I see that your Frigidaire air conditioner will start up then shut off and blink. It could possibly an issue with control panel or the power source of the appliance. I would attempt to perform a reset on the air conditioner which would be removing the plug and pressing the "Test" button, you will hear a click and the button will pop out. Then press the "Reset" button, you will hear another click then plug the appliance in. Those are the steps to resetting your air conditioner, if that does not successfully correct the problem please reply back. I look forward to your response. -Matt
Aug 02, 2014 | Frigidaire Heating & Cooling
Where is the button to reset on a frigidaire air conditioner
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
Jul 23, 2014 | Frigidaire Heating & Cooling
Why does the unit beep when I plug it in.
Good Morning Tina,
I understand that your Frigidaire air conditioner, model# FAM187S2A, beeps and flashes lights when you first plug it in. First, test the power supply cord by doing the following:
1. Plug in your air conditioner.
2. The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
3. Press the RESET button. Again you will notice a click as the button engages.
4. The power supply cord is now supplying electricity to the unit. (On some products this is also indicated by a light on the plug head)
NOTE:
• Do not use this device to turn the unit on or off.
• Always make sure the RESET button is pushed in for correct operation.
• The power supply cord must be replaced if it fails to reset when either the TEST button is pushed, or it cannot be reset. A new one can be obtained from the product manufacturer.
• If power supply cord is damaged, it CANNOT be repaired. It MUST be replaced by one obtained from the product manufacturer.
NOTE: Some plugs have buttons on the top.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 12, 2014 | Frigidaire FAM187S2A Air Conditioner
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
How do I reset the e1 on the A/C
I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book
but on my unit you have to do the following
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
after following this procedure to clear the nefarious E1 indication, you should obtain
another 720 hours of cooling bliss
Jul 20, 2009 | Sharp AFR120FX Air Conditioner
Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Mar 16, 2009 | Amana PTC153B50AM Split System Air...
ARF120
If you have the error code E1 on the LED temperature display. This error code is intended as a reminder for the user to clean the air filter every 720 hours . I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book but on my unit you have to do the following
panel.
button.
Jul 13, 2008 | Sharp AFR120FX Air Conditioner
Reset button
it should be at the plug. should be a test and a reset, like a GFI outlet. if not there is none, let it cool down say a prayer or 2 and plug it back in.
May 07, 2008 | Kenmore 72055 Air Conditioner
Heating & Cooling Logo
291 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
