Question about Black & Decker String Trimmer Cordless 12" 18V
Re: GH1000 Trimmer - looks like the drive belt from the motpor to trimmer shaft either broke or came off. I removed all the housing screws but the housing seems stuck at the button where you can rotate the shaft to be either a trimmer or edger. Any clues on hidden screws, etc still holding that tight or how to seperate them?? thx Paul
  • Anonymous Mar 23, 2014
    I have a 323L Trimmer. How do I remove the Grease filler cap/bevel gear from the shaft? I have removed remove 3 screws and it rotates freely around the shaft but won't come off...
    Champion:
  • 313 Answers
There is one hidden screw under the label. fell with your hand the label where the screw located.
Posted on Jul 24, 2008
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
Trying to remove a clutch rotor assembly on a craftsman trimmer and not sure how to remove it. looks like it unscrews from the shaft
It does unscrew from the shaft. The Torx screw holding it is hidden and doesn't come out of the housing once it is loosened. It is screwed into the end of the shaft. You will have to keep the engine from turning to loosen it. Pull spark plug out and move piston to bottom of stroke. Put some nice, soft, clean rope in the cylinder and let the piston compress it when you turn the Torx screw in the clutch rotor housing.
Jun 30, 2010 | Craftsman 25cc Gas Line Trimmer
GH1000 Motor runs but spool just quit working.this is electric.
Same thing happened to me. The belt broke. You'll need to take off all the screws to change the belt. There's a hidden screw under the black label. Feel around for the soft spot.
May 21, 2010 | Black & Decker 14" Grass Hog Xp...
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same...
remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
Aug 02, 2017 | Echo Garden
Describe your Black &amp;amp;amp;amp; Decker
You have missed a screw about half way, there is one under a sticker.
Sep 03, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
May 25, 2009 | Black & Decker Garden
Take apart method to replace rubber drive belt.
I had the same dillema, till I discovered a soft spot on the label. They put one last screw there. I got the housing open and discovered the belt was broken. Ordered a new belt ($12.39) through ACE Hardware repair center, now I can't get the belt on. That is why I came to this site.
The Ace guy told me he has had lot of calls for this particular belt. If you order one, I suggest you order two.
Good luck.
Apr 16, 2009 | Black & Decker 14" Grass Hog Xp...
GH1000 string trimmer
This is for the Black and Decker GH1000 string trimmer. There are 20 screws to remove altogether. The last screw is under the black label with instructions on using the button to extend the shaft. The screw hole is just above the white line on the label-you have to poke a hole in the label! Very tricky!
May 23, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
330 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
