Question about Sony Handycam CCD-TRV25 Camcorder
Can you transfer info. to computer?
My mom has tonnes of video on her sony ccd-trv25 but there is no fire wire port or usb port that I can see.  Is there a way to transfer tape to computer for editing?
  • gwallace999 Nov 06, 2008
    I have a av to 3 rca cable but I cannot figure out where the cable goes into the camera. There is a 3 prong receptical that seems to work when hooking it direct to a tv. I have found two single ports in the front: one has the picture of an ear (Headphones????) and one says mic (Microphone???) There is another outlet that says lanc (any ideas)? Help.
I found it on line for free.  thanks for your response
Posted on Jul 18, 2008
How to transfer videos from Sony Handy Cam CCD TR 317 E
Check if you have a Firewire port that is either a 6pin or 4 pin port that looks like
Use a firewire IEEE 1394 cable kit and appropriate software too transfer to PC. Most firewire to usb cable will not work.
You will need a
1. Firewire cable
2. Firewire port on PC/Laptop as well.
3. Recent OS that supports firewire.
4. Appropriate image/video editing software.
Apr 22, 2014 | Sony Handycam Video Cameras
I've got the same problem trying to transfer video using a usb cable but my MacBook Pro running OS 10.6 doesn't recognise it
there are also two reasons, firstly you go to menu option in the handycam & search the usb streaming option & than click ON option,second you change your usb wire.
Mar 19, 2011 | Sony Handycam DCR-TRV25 Mini DV Digital...
I need a usb cable to connect my sony handycam model#ccd-trv138 to my computer
CCD-TRV138 is analog camcorder that can not be connected directly with computer by usb cable, this camcorder does not have any usb port to hook it to computer.
Only digital camcorder/ camera can be connected with computer.
Hope these info will help you.
Thanks.
Nov 06, 2010 | Sony Hi8 CCD-TRV138 Camcorder
How to transfer video from my sony handy cam CCD-TRV418E to Comp
You can use a card reader to transfer your file from your handycam to your computer. Remove the memory card in your camera and insert it to the card reader and insert it to your computer to transfer your recorded video.
Mar 07, 2010 | Sony Handycam CCD-TRV418E Camcorder
Need vista support drive
Since Windows Vista doesn't support USB Streaming, it's not possible to transfer the videos to the Computer using the USB connection.
However, you may transfer the videos to the Computer using an i.Link or an AV connection.
The AV port is similar to the Composite port of the TV.
i.LINK is the same as Fire-wire/IEEE1394. It is a D Shaped connector of either 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer.
However, it's required to have the Analog or the i.Link Capture Card installed on the Computer to stream Videos using the AV and the i.Link connection respectively.
It's required to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Fire-wire cable depending on the number of pins on the i.LINK / Fire-wire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
If your computer does not feature this port, you may contact your Computer retailer to install a separate i.LINK Capture card in your Computer.
The software and driver to be used for video transfer will be supplied by the computer manufacturer (if the computer came with an i.LINK interface) or else by the i.LINK card manufacturer.
Click on the below links to get the steps to transfer the videos to the Computer using the:
i.Link connection:-
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111921
AV connection:-
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Mar 04, 2010 | Sony Handycam DCR-TRV460E Digital...
How do i transfer my sony handycam ccd tr416
Use the link below to transfer video to your Computer using A/V cable and the Video Capture software.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C428275
Aug 07, 2009 | Sony Handycam CCD-TR416 Camcorder
I am having a sony hi 8 ccd trv 58 model handycam. i want a driver to transfer my videos to my personal computer. any free drivers available?
CCD-TRV58 is analog camcorder and can not be connected with computer directly as camcorder does not have USB or iLink/ DV ports.
Computer needs digital format movie data to store / edit files.
You need to hook camcorder audio-video out to DVD recorder and burn DVD of camcorder movie so you will get digital format of movie. Put that DVD in computer and copy files for further process.
Apr 19, 2009 | Sony Handycam CCD-TRV58 Camcorder
I have a Sony Video8 Handycam CCD TRV211.
If you are asking about CCD-TRV211 camcorder?
CCD-TRV211 is analog Video-8 camcorder so its movie data is not digital and can not be connected directly with computer via USB port.
Best and easiest was is to connect camera with DVD Recorder and burn DVD, this will convert analog movie file into digital data and you can copy it to hard disk of computer.
Mar 31, 2009 | Sony Handycam CCD-TRV308 Camcorder
Transfer of video.
If model number is correct i.e CCD-TRV67, means its analog camera and can't not be connected directly ( USB ) with PC. Suggestion is to record movie on DVD by any DVD-Recorder to get analog signal in digital format. Now you can transfer it in PC.
Hope this info will help you and if you find it helpful, give vote as fixya.
Aug 18, 2008 | Sony Handycam CCD-TRV67 Camcorder
Video transfer from sony handycam ccd-trv 308 hi8 to a computer
I have a sony handycam ccd-trv 308 hi8 analog camcorder and I was trying to transfer videos from it to my computer. However, when I plug the S-video cable to the handycam and my computer, nothing happens. Does my computer require a driver to recognize the handycam because I cannot find any in the sites of sony for my handycam's model. Or am I using the wrong wire?
Apr 06, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV25 Camcorder Logo
255 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
