Question about Garmin GPS
I have a new garmin 705. Once the unit is connected I cant get any of my computers, Mac or pc to open the file formats gpx or tcx
  • kurt441 Jul 17, 2008
    Thanks!!
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE to download program to open TCX format..Select your operating system from there.
Posted on Jul 17, 2008
  • Garmin Master
  • 13,433 Answers
Have you installed the software that came with the garmin?
My Garmin 705 is frozen with the garmin logo. Cant get pass that. Any ideas?
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults .reassemble
Mar 21, 2013 | Garmin Edge 705 Handheld GPS Receiver
Tip
Backup and Restore Favourites on Garmin Nuvi Satnav
If your garmin nuvi satnav becomes faulty it may have to be reset or indeed scrapped. Either way you lose the places saved in your favourites folder.
If you have backed them up to your computer it's a simple matter to restore them to your reset nuvi or to a new one.
To Backup Favourites in GarminNuvi Satnav
Instructions for PC:
  1. Connect the Garmin nuvi satnav to your computer
  2. Go to the Start menu
  3. Choose My Computer (or Computer for Vista and Windows 7)
  4. Right-click the Garmin nuvi drive and select Open
  5. Double-click the Garmin folder (For nuvi 1xxx series units skip this step)
  6. Double-click the GPX folder
  7. Right-click on the Current.gpx file
  8. Choose Copy from the right-click menu
  9. Right-click on any blank area on the desktop
  10. Choose Paste to put a copy of it on your computer's desktop
Instructions for Mac:
  1. Connect your garmin nuvi satnav to your Mac
  2. When you see the Garmin nuvi mounted to the desktop, double-click on it
  3. Double-click on the Garmin folder (For nuvi 1xxx series units skip this step)
  4. Double-click the GPX folder
  5. Click once on the Current.gpx file
  6. Go to the Edit menu at the top of the screen
  7. Click Copy "Current.gpx"
  8. Click any blank area on the desktop
  9. Go to the Edit menu again
  10. Click Paste Item
Now, if for some reason you need to put the file back onto your garmin nuvi satnav, you will need to send it over to your satnav using a program. For the PC, you will need MapSource which can be downloaded at:http://www8.garmin.com/support/download_details.jsp?id=209
To send the file back to the satnav using MapSource on a PC:
  1. Connect your Garmin Nuvi satnav to the PC
  3. Highlight All Programs (Or just Programs for Vista and Windows 7)
  4. Highlight Garmin
  5. Click MapSource
  6. Click on the File menu
  7. Select Open...
  8. At the top where it says "Look in:", select Desktop
  9. At the bottom where it says "Files of type:" select GPS eXchange Format (*.gpx)
  10. Click on the Current.gpx file
  11. Click Open
  12. Click on the Transfer menu
  13. Click Send To Device...
  14. Select the GPS in the Device drop-down list.
  15. Click Send
Currently MapSource does not work with the Mac operating system so you'll either need access to a windows computer or a windows environment on your Mac to send the file back to your satnav.
on Feb 23, 2011 | GPS
Tip
Garmin POI, GPI, GPX, GDB and CSV and how not to be confused
GPX or CSV file can be converted to the proprietary Garmin format GPI format (Garmin Points of Interest) format using the Garmin POI loader v2.54 OR use the one bundled with the Garmin Map Source v6.15.11 at the time of posting if there is also a BMP file of the same filename then this will be added to the Waypoints Symbol.
If you put all your POI that you want to be added to the Garmin POI then place all them in the same folder prior to starting the POI Loader and they will be placed into sub-menus otherwise it will select the single file entries only.
However the Garmin Mapsource can't open this GPI format it is specifically for the SATNAV Device only open GDB, MPS, GPX and LOC files can be opened as standard. There are two ways that I know of that will convert this GPI back into CSV or the POI format if required you might like to open the POI content in the Map Source program.
First this can be done using GPI2GPS it does however cost 15 EUROs or its older brother GPSConvertor for an extra 20 EUROs will convert to all formats for all makes of device including Tom-Tom, Garmin and many others.
Secondly you can convert POI file in CSV format directly to GPX (exchange format) using the excellent GPXtoPOI Convertor v1.1.8 then import directly into the Map Source if you also want to use BMP that has been downloaded in Map Source you can replace the 8 default custom waypoint symbols located on your computer with your own or from the Tescos.ZIP file in this example that contains the CSV and BMP.
You can open these symbols with a graphic editor and use them as templates for creating your own symbols.You can add up to 64 custom waypoint symbols. These symbols must be in .bmp format and must be named numerically from "000.bmp" to "063.bmp." Custom waypoint symbols can be 16 x 16 pixels (small) or 24 x 24 pixels (large) and up to 32-bit color
Also check out my other POI tip HERE for help on how to create your own BMP's for use with your Garmin using Adobe Photoshop
It will also convert any GPX format into CSV format for use with the POI loader using the other button on the menu maybe this program would be best called GPXtoCSV instead to avoid confusion
And this one I saved for last If you want to transfer images from the Garmin use xImage and have your Garmi SATNAV connected.
For a full list of all POI sources then visit the Gamin POI Source another great website full of loads of useful tools is www.freegeographytools.com
If you are unable to use xImage it means that you unit is not compatible for example the Nuvi 250 will not be found and you may see this window
on Apr 18, 2010 | Garmin nuvi 250W GPS Receiver
Garmin 705 - device not found by Training Center
Garmin has moved everything to Garmin Connect. Depending on your device, Training Center may or may not be supported anymore. You can go to the link to read more on Garmin Connect. Also, Garmin now uses Garmin Express to sync and update devices. I'll attach the link. https://www.garmin.com/en-US/software/express
Aug 16, 2017 | Garmin EDGE 705
Unable to get satellite connection for nuvi1390
There is a possibility that the antenna is defective or another component of the device. You may need to reach out to Garmin Technical Support for repairs or replacement, however, you can try the steps below to try and resolve the issue.
-Perform a hard reset (this will delete any settings you have on the device. After you perform the hard reset, you want to put the GPS unit outside for about 30 minutes or until it acquires a signal. Afterwards, you want to hook it up to your computer and make sure all the software is up to date.
To perform a hard reset, unplug it from any power source and turn it off. Press and hold the bottom right of the GPS screen continue to hold while you power on the device. Once it is powered on, you should get a prompt asking you if you wish to delete the data. You want to press Yes. Next, leave it outside in a safe place to acquire a Signal. If you want to backup your favorites, see below.
You can backup your favorites by doing the following.
In order to back up your Favorites:
1. Using a USB data cable, plug the device into a computer
2. Double-click the My Computer icon (Mac users can skip this step)
3. Double-click the nuvi drive (Mac users can find this on their desktop)
4. Double-click the Garmin folder1
5. Double-click the GPX folder
6. Copy the current.gpx file
7. Paste this file to another location on your computer
Once you save a copy of the GPX file on your computer, you have successfully backed up the waypoints within your device. Now you can RESET it.
To restore these Favorites on your device:
6. Copy the current.gpx file saved to your computer
7. Paste this file to the GPX folder
8. Unplug the device from the computer
At this time the favorites you backed up should be restored on your device.
Regards,
G33k
May 15, 2011 | Garmin GPS
Hi I have a garmin nuvi 765 that just stopped working
I called Garmin and they had me do a restoral and it solved my problem.
If you have a lot of favorites and you want to keep them you will need to save them first to reinstall later.
To save your favorites: Plug in your unit to your PC. Open an explorer window and navigate to the drive associated with your Garmin. Double click on Garmin and you will see a sub folder named Garmin. Click this folder and click on the GPX folder. Copy the current.gpx file to your desktop. Be sure you rename it.. They had me rename it to current1.gpx
Now, unplug your unit from your PC and shut your Garmin off…. Then hold the bottom right of your touch screen and turn the unit back on while holding the screen…. Follow the prompts… I cannot recall each, but answer yes to you all…
Once you are back on the main screen (Where To and View Map) plug your unit back to your pc so you can bring your favorites back.
Navigate to the drive that is associated with your Garmin and copy the current1.gpx file from your PC desktop to the GPX folder… you should now have two; one called current.gpx and the one you just pasted called current1.gpx…
You are now ready to go and try it out in your car… Mine worked and all my favorites where there as well.
Hope this works for you as well
Jan 20, 2010 | Garmin nuvi 765T GPS Receiver
HOW COULD I TRANSFER MY FAVORITES FOLDER FROM MY GERMIN 765T TO MY NEW ONE SAME MODEL ?
Connect your Garmin to PC with USB cord. Open Garmin/GPX folder and copy the current.gpx file to pc and rename it to temp.gpx. Then copy the temp.gpx back to the new Garmin/GPX folder. Unplug Garmin. Turn off/on and your favorites should be back.
Oct 25, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Cant delete gpx files from 705 edge memory. done all usuall stuff on pc, even tried deleting gpx folder but routes still appear in saved rides when unit re-powered up. any ideas anyone?
Only one idea ... Perform hard reset. Garmin devices have often data corruption issue, that can only be solved by return to factory settings :
Device powered off, press and hold mode and Power on buttons for 10 seconds, then pulse press lap/reset button.
You will be asked for confirmation, confirm, your device should be OK then.
Also update the firmware, you'll get last fixes for data corruption ... (does not mean there are none remaining ...)
Jun 24, 2009 | Garmin Edge 705 Handheld GPS Receiver
How can i download movies/videos on my gpx ML638b?
all you need to do is go to google and download a AMV video converter tool. once you do that put the video on the converter and start it. then click on My Computer, then click on GPX MTP Device> Removable Storage>. and then copy the video wherever the conveter saved it and then copy it. then paste it in the Music Folder on your mp3.
Ps. i am haveing a problem with charging it. i got videos on it but i cant charge it here is my problem...
http://www.fixya.com/support/t1568066-get_charge
Jan 17, 2009 | GPX ML648B MP3 Player
GPS Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
